I just received my Topstone Neo Carbon 2 with Kiox display. When I turn it on I'm greeted with "Error 550 - Please contact your bike dealer". Is this something I need to worry about? I have wiring for lights but no lights installed yet. Is it related to that?
Some manufacturers now have representatives making helpful contributions to this forum. Bosch is one example. If forum members have our own product improvement suggestions perhaps one option is to add any suggestions to this thread with a specific subject line clearing identifying the suggestion and details in the body the post. I would not expect Bosch representatives to respond to every suggestion but forum members could give a thumbs up to the suggestion and Bosch would be expected to acknowledge those that have merit.
If you wish to expand on an individual suggestion subject perhaps start a seperate thread in the forum rather than a reply to this one so that the focus of this particular thread is a summary of individual suggestions. Refer "Low Battery Cutout for Bosch Gen4" thread where a single suggestion is now multiple pages. If you post a suggestion you may wish to start this seperate thread with the same title to generate feedback from forum members as distinct from Bosch.
If you think this is a useful idea please complete the poll and/or give this a thumbs up and Admin may arrange to keep this type of post at the top of the sub-forum.
My instinct leans towards checking that the spoke magnet is lined up correctly. I'd start there.
The internet says it means " An improper electrical load was detected.". Can mean "I'm expecting load from lights but there is none" or "your dealer hooked up something wrong you better go have them fix it".
I haven't read the thread but the only thing I would ask of Bosch is that they unleash the power of Bosch. They could make Bafang motors second rate. There's plenty of market here for powerful ebikes. Why not? You have the manufacturing power and know how in spades. The US has millions of sq miles of private land where we can ride anything we like. And those of us who want real power in ebikes will get more and more public land opened up to high watt ebiking. Just produce 750 watt bikes. Legal in many states. You don't make weak low power tools.
Sorry to hear you've got an issue right out of the gate. As was suggested by some others, will likely need a visit to a dealer with the Bosch Diagnostic software.I just received my Topstone Neo Carbon 2 with Kiox display. When I turn it on I'm greeted with "Error 550 - Please contact your bike dealer". Is this something I need to worry about? I have wiring for lights but no lights installed yet. Is it related to that?
Good instinct! Very close, but the spoke magnet/speed sensor error codes start with 503.My instinct leans towards checking that the spoke magnet is lined up correctly. I'd start there.
Bosch is not permitted to change the circumference value on an OEM's product, so this will require some help from Cannondale... your shop will have to coordinate with them to check the OEM-programmed Wheel Circumference on your bike against what Cannondale has on record for that model. Assuming the issue is caused by an incorrect circumference value (majority of cases like this are) the rough order of next steps is:Regarding the roughly 3 - 3.5 km/hr discrepancy I'm seeing with my new bike and the Bosch Activeline Plus / Purion system... my bike shop had this to say...
" I'll have to call Bosch about the speed error, I'm not too sure what we can do without their assistance. Their programming is pretty well guarded against "mods". I'll get back to you next week with more info. "
William, if you read this, is there a plan of attack that you can suggest?
To summarize the problem, the Purion is reading 31 km/hr when my actual speed is 27.5 - 28 km/hr, as measured by my Wahoo speed sensor and Wahoo Roam and also compared to other riders when on group rides. The difference is consistent. This means the assistance is cutting out much sooner than it should be if I understand things correctly. I'd welcome any thoughts you might have. Thanks!
- Shop performs a "roll-out" on your bike with proper tire pressure and approximate rider weight. This won't be the exact circumference number the OEM uses, but it should show what it should be close to. All OEMs use a slightly different factory method to get this value, but again... it should be close.
- Shop checks this roll-out value with Cannondale. Assuming Cannondale finds this to be "off," Cannondale sets up a Remote Diagnostic session with your shop to change this value to what it should be.
There is the 5% "cosmetic" adjustment that the shop can make, but that only alters displayed speed. The bike will still cut-out at the same speed as before, even if it reads a different number. Loose rule of thumb is that if the 5% cosmetic doesn't make it seem right, time to talk to the OEM or Bosch.
All Bosch Systems should cut-out a little before the stated max assist, but this is a smaller value assuming the speed is otherwise correct.
May be the opposite in Europe, insurance-wise etc.You are all going to suffocate under all the red tape YOU produce.
I can appreciate the feelings on this one. I'll try to provide some background:You are all going to suffocate under all the red tape YOU produce.
There are some pretty serious regulations in place that require us to take considerable measures to ensure that consumers cannot easily modify the product to exceed maximum assist speed for a given class. I'm guessing, but not positive, that OEMs are held to the same standard, especially since they are the manufacturer of the eBike. This makes things a little more complex when it comes to sorting out speed related issues as there are rules/laws above and beyond Bosch or the OEM partner that dictate what action we are permitted to take.
Though it may not always seem this way, nothing we do is designed to make things more difficult. Our focus is safety and compliance.
It definitely feels that way sometimes. I'm sorry you are having an issue with your brand new eBike.I really really don't like the sound of this finger pointing back and forth between OEMs and Bosch. Nothing good comes out of this setup for the consumer. I too am trying to figure out a motor error I have with my brand new Cannondale bike. Cannondale says it's Bosch I need to contact, Bosch says I need to take it to a Bosch eBike Service Center which my Cannondale dealer is not. It's like getting worst of both worlds. It will be grand if the Bosch service says OEM tweaked this and set it up their way, so we are not responsible.
