My original ideas were primarily for myself in the future, a possible switch to E14, i currently have a manual shift Rohloff and already shift gears very nicely thank you very much!
The ideas i had were to maybe get the E14 as close as possible to the non-E14 shift in flexibility & speed.
I don't know exactly what happens in the 180-200ms (Rohloff site quotes these times) apart from a Bosch motor power reduction and the shift being performed but if there is a quicker smoother way that allows more control for a "pro" Rohloff rider then i'd be keen on it.
But on the other extreme the ideas i mentioned could also be used to make it easier for newbies, etc. and safer for the Rohloff.
eg.
scenario 1: You lend your E14 bike to a family member, friend, whoever and you know they will have trouble shifting so you put it in "beginner" mode.
scenario 2: Your company has a fleet of R&M Loads or whatever with Rohloff's as you wanted longevity, efficiency & gates belt (low maint.). Many different employees use the vehicle so to keep the Rohloff's longevity you mostly have it in "beginner" mode. The occasional employee can use "experienced" or "pro" mode.
scenario 3: You used to be a Rohloff "pro" but have had an accident and can't shift like you used to.
scenario 4: Rohloff provides ebike company/end user an extra 2 or so years warranty provided the system is fixed on "beginner" mode and services are performed as required.
etc.
Possibly coupled with input fed from the Bosch torque sensor in the "beginner" mode so as to allow:
If cutting the motor out is simply not enough in-conjunction with too much force applied to the cranks then to keep the motor cut? & not initiate the shift, instead displaying a msg on the screen instead.
A complete protection for the Rohloff from inadequate shifting conditions - most helpful for the above scenarios i described.
And of course as i said, this could be applied to Kindernay & others. (when they get their own semi-automatic/electronic shifting system, which surely is only a matter of time?)
Or it may be a future feature in a non CAN bus group of ebike/motor manufacturers based on FlexRay, Automotive Ethernet or some other/new Open Source vehicle communication transport.
Of course any new integrated motor/gearbox (eg. Bosch motor & Rohloff in one unit) you would think would have this kind of automatic/semi-automatic control.
If the E14 can shift with only the motor cut but with crank force applied by the rider and do that safely then that paves the way for a fully automatic system if the end-user so should desire.
Or perhaps i'm getting carried away!
