Sorry, my experience with blutooth comms has been awful. Dropouts, battery issues, talk-to-send has lag that drops the first part of any sentence... I use wired comms and love it. Clean, does what I need it to do and stays out of the way.Get some bluetooth comms too and you will be set.
Back in action. The replacement rear shock is fitted. The ill fitting Kiox controller that caused its battery not to charge properly has been fixed.Replacement rear shock has now been dispatched from Germany.![]()
Hi, I’m curious why you also installed the Kinekt 2.1 on the Homage? Was the rear suspension not enough travel? Don’t these work against eachother a little bit? Thanks.Brooks saddles are renowned for being rather uncomfortable for the first 500-100km until the leather is "broken in" and as good as it gets once they are. It would be great if saddles worked perfectly from the get-go. I've only had that happen with a Selle Anatomica, which is also leather. It did not need to break in, but it did need to stabilize. they are designed to stretch and sag initially, and to be progressively tensed up until they stabilize. When the gap in the split remains about 6 mm, it's stabilized. If it is comfortable for an all-day ride, especially when ridden with a properly padded set of shorts.
This is a 2019 Homage Rohloff HS that I owned with the S A saddle.
View attachment 91818![]()
Comfortable Leather & Rubber Bike Saddles | Selle Anatomica
Shop anatomically designed bike saddles built for long-ride comfort. Compare X, H, and R Series, choose your frame, and ride pain-free.selleanatomica.com
Actually they compliment one another. The rear shock smooths out the larger flaws encountered in the bikes path, potholes, sticks, heaves and bumps. The Kinekt is much quicker acting and works well to reduce the higher frequency, small impacts to the bike as it goes over gravel, twigs, and smaller imperfections in the road surface. The Kinekt offers a further refinement in the ride. I already had it on my prior bike which was a hard tail. I am not sure I would have sprung for it just for the Homage, but it did make a subtle but noticeable difference in a positive way.Hi, I’m curious why you also installed the Kinekt 2.1 on the Homage? Was the rear suspension not enough travel? Don’t these work against eachother a little bit? Thanks.
That’s very interesting - thanks for sharing!Actually they compliment one another. The rear shock smooths out the larger flaws encountered in the bikes path, potholes, sticks, heaves and bumps. The Kinekt is much quicker acting and works well to reduce the higher frequency, small impacts to the bike as it goes over gravel, twigs, and smaller imperfections in the road surface. The Kinekt offers a further refinement in the ride. I already had it on my prior bike which was a hard tail. I am not sure I would have sprung for it just for the Homage, but it did make a subtle but noticeable difference in a positive way.
I’ve used several Brooks models on a similar bike (Nevo), upright position, using only a Thudbuster. No problems, no issues with daily riding of 70-200 miles.Back in action. The replacement rear shock is fitted. The ill fitting Kiox controller that caused its battery not to charge properly has been fixed.
After a 82km ride last Sunday, the 'comfort' saddle is proving not to be the nirvana that I was seeking (unrealistically?). At 175cm tall on a 49cm frame, the comfort package is providing a very upright riding style reminiscent of a Dutch Galaxy bike that I used to own. The angle of the stem seems suitable for me and I have done a lot of tweaking of the height and angle of the saddle to get the best possible fit. While my arthritic wrist and neck are grateful for the upright setup, the pressure from the seat is not so welcome.
My question today - Should I consider a Brooks B17 saddle which is recommended for a 60° body angle rather than an upright position? Does anyone have any experience of a B17 with an upright style of riding.
Brooks also make a "softened" version of the B-17 that is pre-broken in and much more comfortable right off the bat. They are hard to find thoughI’ve used several Brooks models on a similar bike (Nevo), upright position, using only a Thudbuster. No problems, no issues with daily riding of 70-200 miles.
I used Brooks saddles long before ebikes as well. What I’ve noticed is either ppl love them or hate them. Your wife will know within two weeks if Brooks and her butt will get along. That’s what it comes down to. im not sure if they still offer the woman-specific B17, so check on that. It’s a bit wider.
While the saddle / bike are for me not a wife, the Homage with comfort bars / saddle is significantly more upright than my previous Nevo.I’ve used several Brooks models on a similar bike (Nevo), upright position, using only a Thudbuster. No problems, no issues with daily riding of 70-200 miles.
They still make it, but if I recall it's not wider, just has a shorter nose.I’ve used several Brooks models on a similar bike (Nevo), upright position, using only a Thudbuster. No problems, no issues with daily riding of 70-200 miles.
B67 is 30mm wider than B67.They still make it, but if I recall it's not wider, just has a shorter nose.
I recently sold my B67. A bit too heavy for my taste. Def feels like overkill with the Homage.While the saddle / bike are for me not a wife, the Homage with comfort bars / saddle is significantly more upright than my previous Nevo.
Brooks promote the B67 for an upright style of riding but those springs do not seem appropriate for the style of bike.
And yet the comment I was replying to was referring to the women's B17. Thanks for the gigantic images tho.B67 is 30mm wider than B67.
Lol.And yet the comment I was replying to was referring to the women's B17. Thanks for the gigantic images tho.
I have the Homage and Thule Easyfold 932 and I load it exactly as per your photo (the only way it will fit on in fact), but it has concerned me each time I use it because the grip is weak, due to the height of the rail that holds the bike holder arm being about 80mm below the lowest position that you can clamp the bike at on the seat stem, does anyone else find this a concern? I have been considering upgrading to the Easyfold 934 carrier, where the rail carrying the arm is almsot 100mm taller. With a taller rail, the jaws of the holding arm will meet the frame more squarely, meaning the jaw will get a much fuller grip on the frame (at all four edges of the clam grip), instead of just two edges due to the angle of approach, if you get my drift? If you look at my photo you will see that the jaw is about 5mm away from the frame when fully tightened, the same is true for the opposing bottom jaw, not good.Picked the bikes up from Kelly at Citrus Cycle. Took a quick test ride and now waiting for the ferry. The Nevo and Homage were a very tight fit on the Thule but it works okay
Love the power of the Gen 4 motor - noticeable difference
Glad I ordered the comfort bars. I am an old geezer and the upright riding position suits my back and neck
The X5 is new too so we are doing our bit to support the German economy.....
I’ll post more feedback after a few more rides
