Thanks for confirmation
Darlinsk and
Alaskan! But actually charging the phone is the last thing I care about here. Let me explain. For last 6 month I am in search for perfect camera setup for my bike (I am riding though the NYC a lot, so I want to have recording just in case something happens) - so I am looking for something like car dash cam. My requirements are:
- descent video quality (so the plates are readable)
- ability to have "infinity storage" (new videos overwrites old when storage is full)
- ability to integrate with my bike, so I don't need to think about charging and turning on/off the camera.
While first two criteria are pretty basic and there are lots of options, it is difficult to do something with 3rd option, but with SmartphoneHub I was able to get it working almost like I want. And how, after upgrade I lost that and need to start my research from scratch
![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I am using
Drift Ghost XL camera mounted under the front light and it has a special waterproof power connector (using 3.5mm audio jack which screws in the came case one one side and regular USB connector on other). Also, this camera has a "dash cam" mode, when it powers on / start recording when powered on via the cable and stop recording / powers off when power is disconnected. Since SmartphoneHub has a power port, I just made a special cable from the one coming with the camera and one coming with the Hub, so camera is always connected to the hub port. And this was giving me a trouble-free camera setup:
- camera is powered on from the bike battery - no need to worry about it is dead since I forget to re-charge it
- camera starts recording after I start the ride (SmartphoneHub powers on the port the app when the phone is connected to the hub and I am in riding mode)
- camera stops recording after I ended the ride (SmartphoneHub powers off the port the app when the app is closed and phone is discconnected from the hub)
I used it few month in this way and it was working fine. And I was hoping to get similar with Nyon since it has a USB port (my fault I never double check it is suitable for charging, but knowing the even Kiox has it I have zero reasons to not expect much more advanced and expensive display can't do this like basic Purion can't), but my hopes are dead now. My plan now to explore the option to use some power from front/rear light power input (it has 12 volts, so I will need to use car/motocycle usb outlet with built-in convertor), but I am still not sure will it work and if is it enough power there to share between usb port and light itself.
