Wahoo ELEMNT vs. Garmin EDGE (as E-Bike GPS Displays)
You said Garmin reflected the perceived temperature. How can a thermometer that is fundamentally inaccurate reflect anything? Pity you don't get frost in AUS because I would like to know your opinion on how Garmin would "reflect actual road conditions" :D Would it report -5 C with the actual temperature of zero? Or, +5 C? :)
Please do not make up what I said. My words are here in black and white.
What I actually said:
In my experience, my Garmin one has, at least in the past ( I do not bother with temperature nowadays), reflected the temperature on the bike, that is the heat radiating from the road as opposed to reported or ambient temperature. I actually found this more useful, e.g., 50 C on the bike in the summer versus 40 C reported by the BOM.
I cannot understand your irritation, Andrew.
I expect quality instruments from expensive brands, market leaders, that's it.
I need to repeat myself. An instrument that does not work simply does not work. It does not reflect the heat radiated from the road. It is five centigrade off.
Wahoo is - 3 C off in the winter. It is -4 C but the reading is -7. I do not say Wahoo reflects the perceived temperature. It is inaccurate.
Personally the only time weather info is really useful is before I ride, so I know what to wear and whether to bring extra layers. Once I'm on the bike, eh, I'm experiencing the weather and knowing the exact air temp isn't useful info anymore. I don't need the computer to tell me if if its cold or hot.
I guess if you're super into data and training it can be nice to have the air temp recorded in the fit file so you can, like, go back and check temps on previous rides?
What if the weather forecast told you it would be 7 C but then you are on the race and it is between 2 and 5? There were cases of hypothermia on the race. Not sure how long do you stay on the ride during inclement weather but my last race was five and half hour.
I was even not looking at my Workout screen where the thermometer is but well, you can see it post-ride, too.
RideWithGPS has extracted those data. Strava only tells the subscriber the starting and ending temperature by weather data.
If I brought extra layers I'm putting them on when I feel cold, not when the computer says the temp has dropped. If I didn't bring extra layers I'm SOL no matter what the computer is saying.
As someone who does (or has done) long-distance touring and Audax rides, the temperature on the bike computer is something of interest at the end of the ride if I can be bothered to look, just to know how hot or cold it got. If it was freezing during the night on the ride, it was freezing. The number is not going to change that.
Personally, I have learnt to simply plan to be prepared.
On multi-day rides, even during the dry season, I still take rain gear and layers because if I do not, it will rain/be damn cold overnight for sure :).
As an aside, I learnt that lesson once, and once only on an overnight bushwalk when the forecast in the area was for zero rain. It bucketed down the next day, and of course, I had gone ultralight ... early signs of hypothermia were my reward when I eventually reached the car.
The most miserable ride I ever did was a 50ish mile road ride with a bunch of friends. Weather was forecasted to be relatively warm and sunny, but we got to the 25 mile point and a sudden cold front and storm rolled in. Temps dropped like 20 degrees and it absolutely poured on us. I barely remember the last 10 miles or so; I was so cold that I was having trouble clipping in because my feet were numb. Apparently I fell so far off the back that everyone stopped to wait for me and I rode right by them like a zombie. I vaguely remember thinking that if I stopped pedaling I probably wouldn't be able to start again.
Second worst was BikeDC in the late 2000s when they held it in the fall. Was in the 30s and raining all day and I decided to ride the ~40mile round trip to the start and back. I knew the weather was gonna suck but just didn't count on my rain gear not working for a full 70 miles, and also didn't anticipate standing around waiting for the ride to start for 45 minutes in the rain (after riding 20 miles to get there). After the ride I had to hit a starbucks in Crystal City and just hold a hot chocolate in my hands for 10 minutes to warm my hands up for the ride home.
In any case, all a bike computer temperature reading would have done on either ride is put a number to the suffering I could do nothing about. :p
I wonder why people install the thermometers outside their home windows at all. They have the forecast and generally cannot help the weather at all, right?
My whole point was: if Garmin (or Wahoo) decides to install the thermometer in the bike computer, let it be reasonably accurate. The readouts are interpreted digitally. Should be no problem to put 20 devices into the thermostat, do a curve, then apply the calibration curve in the firmware, that's it. They don't care and it only means how much they care about their customers.
Jeez, guys. All he wants is to have his temperature gauge read accurately in his (not cheap) bike computer. That's a very reasonable expectation. I had a Wahoo Elemnt. The temperature gauge was accurate to within 1 degree F. I have a Garmin 830 now, because I prefer how the Varia works with it, and color navigation is better for me. It is within 1 degree F in the shade, but on the road in varying sunlight, it's wildly inaccurate.
I know the accuracy because I have a reference. My home weather station has a calibrated thermometer, calibrated at the factory. I also own a handheld electronic scientific reference thermometer that is accurate to 0.01 degrees F. The two match within 0.1F, which is in spec for the weather station.
From the Garmin manual for my 530...
Temperature Readings​
The device may display temperature readings that are higher than the actual air temperature if the device is placed in direct sunlight, held in your hand, or is charging with an external battery pack. Also, the device will take some time to adjust to significant changes in temperature.
If anyone of you owns a Wahoo ELEMNT Bolt 1 or Roam 1, you need to install the latest firmware update:
Firmware update procedure
A friend has a Roam 1 and she thought her device was dead. I have guided her through the update procedure. It is funny to find out how many users do not have their Wahoo ELEMNT properly connected to their home WiFi... Now, the friend's Roam 1 works properly!
Ras, to save me 21 minutes of life please tell me what the e-bike in question is and whether Coospo can recognise the SL Range Extender.
Thank you!
I just got the Coospo CS 600 which is the latest model. I chose it because I didn’t need route mapping - I almost exclusively ride rail trails near my home - nor am I concerned about battery levels to the degree you are. It doesn’t have Ebike functionality but I can obtain speed, cadence and rider power from my Vado SL and that’s all I need.
The problem the Coospo solved for me is battery life when on my phone or watch when I go on rides longer than two hours. I’ve only used if for one ride so far and it met all my needs for that ride. Since I don’t need any of the other bike computer features paying just over $100 made the choice a no-brainer. I do use an HRM because the my primary cycling motivator is coronary health.
Different folks have different needs
So it means your computer is somehow connected to the Vado SL. Why no e-bike battery level? Weird!
P.S. @BEC111: I have read some Coospo material. It clearly states the computer can work with e-bikes. If you get the cadence and pedal power it means Coospo is connected to two sensors of your Vado SL. I think you could try deeper to find the LEV Battery data. You may need that as Vado SL 1 has no display whatsoever!
Stefan, you may be correct. The device connects via ANT+ and can access the relevant sensors on the bike, but it doesn’t appear to be able to see battery status. I will have to look for it on my next ride. It’s not that important for me as I rarely ride to the limits of battery life so even the simple bars on the TCU are adequate while I ride. I use the Specialized app before and after a ride to get more accurate levels so I can plan for charging, based upon my expected next ride length.
Since battery status remains an open question, I’ll post my findings, though it might take a while since the weather is currently outside my comfort levels. My other next test will include uploading a saved Ride-With-GPS route to see what that‘s like.
