Dewey
- USA
- City
- Arlington, Virginia
They look stately and professional.I think the Gazelle bikes are aptly named. They are so graceful looking.
Im liking the belt drive designs. Less maintenance and smoother shifting. What are the real downsides to a belt drive?More information from Electrek... https://electrek.co/2020/10/21/gazelle-announces-new-electric-bicycles-ultimate-c380-belt-drive/
I'm with Stefan on this one. Especially with $3000 to $4000 ebikes. There better be some dang nice components and specs on them. And if you can't tell at first glance on line, then pass. (And no the Dutch are nowhere near 'ahead of everyone' on manufacturing. That's an awfully broad platitude to be conjecturing upon.i would agree however they are the market leader in the Netherlands. )A little harsh Stefan, the Dutch are ahead of everyone else when it comes to ebikes. Have you seen their indoor test track De Fietser? I find a lot of appeal in Gazelle’s attention to detail including using rust resistant hardware, full chain cases, and now belt drive, designed to be left out the rain. I wish the British government supported cycling infrastructure and domestic bicycle manufacturing the way the Dutch do.
The Cube Kathmandu is excellentI have nothing against Gazelle. I wouldn't buy a Gazelle because of the poor information on their website. Two different matters. I would buy a Cube instead because I not only love the looks of their e-bikes but also the proper specs on their website![]()
Higher up front costs is the main one. The seat stay has to have a break in it to install the belt. And also higher parts cost. Some folks are concerned about the higher tension of the belt reducing bearing life in the IGH. Also if you want to change the gear ratio by changing the chainring, it will be more expensive and could be very difficult to find the correct length belt.Im liking the belt drive designs. Less maintenance and smoother shifting. What are the real downsides to a belt drive?
Thank you for this. Most of these issues sound like edge cases where youd want a LBS to handle it for you and shouldnt happen more than once in a year or even several years.Higher up front costs is the main one. The seat stay has to have a break in it to install the belt. And also higher parts cost. Some folks are concerned about the higher tension of the belt reducing bearing life in the IGH. Also if you want to change the gear ratio by changing the chainring, it will be more expensive and could be very difficult to find the correct length belt.
I wish we had a dealer near. I've never seen one in person. Nor a gazelle for that matterThe Cube Kathmandu is excellent
Could it be that they simply plan to sell their bikes to dummies?Gazelle baffles me by inadequate specs of their e-bikes given in their website. Look to Specialized, Giant, Trek, Cube, etc. sites: Even the smallest components are listed in detail. Gazelle gives descriptors:
Fork material: aluminium
Fork suspension type: telescopic
Travel Fork: 80 mm
What fork is it? Air Spring or Coil Spring? Make? QR or Thru-Axle? What size of the axle?
Or,
Gear system description: 10-speed Shimano XT (what groupset, what shifter, what gearing?)
Gear type: derailleur
Gears: 10 (What cassette, dammit!)
Rear derailleur: Shimano XT
Front chainwheel: 55
Brake system short description: hydraulic brakes, 4 piston (What brakes, exactly?)
Brake Front: disc brake with hydraulic control (What rotor size?)
Brake Rear: Disc brake with hydraulic control (What rotor size?)
Now, Specialized (Vado 5.0):
FORK: SR Suntour NCX E25, alloy steerer, 15mm thru-axle, 44mm offset, 50mm of travel
REAR DERAILLEUR: Shimano XT, Shadow Plus, GS cage, 11-speed
SHIFT LEVERS: Shimano SLX, 11-speed w/ Optical Gear Display
CASSETTE: Shimano SLX, 11-speed, 11-42t
CHAIN: Shimano HG601, 11spd
CRANKSET: Custom alloy forged crankarms
CHAINRINGS: 48T, custom alloy
FRONT BRAKE: Shimano Deore XT, hydraulic disc, 180mm
REAR BRAKE: Shimano Deore XT, hydraulic disc, 160mm
However Gazelle e-bikes look like, I wouldn't put a cent for an e-bike with so undefined specification... Because I feel they're trying to cheat me.
P.S. Gazelle might hire a native English speaker to maintain their website. Their Dutch English is poor there. "Engine"? Really? "Chainwheel"?!![]()
