Some 3rd Party Chain Lube Testing Data
smorgasbord
Chain lubes are among the contentious discussions in the biking world, and EBR is no exception.
Some here may know of the Australian company ZeroFrictionCycling and its extensive testing efforts over the years. Their testing protocol is well-documented, uses a motor-driven actual bicycle drivetrain.
It's a 5-stage test:
Block 1 - Clean environment for 1,000 kms. Measure wear then proceed to
Block 2 - Dusty/Sandy environment for 1,000 kms. Measure wear then proceed to
Block 3- Clean environment for 1,000 kms. Measure wear then proceed to
Block 4 - Wet environment for 1,000 kms. Measure wear then proceed to
Block 5 - Clean environment for 1,000 kms. Measure wear then proceed to
Block 6 -Extreme contamination for 1,000 kms. Measure wear.
Chains are not cleaned once the test starts. Re-lubing is done per manufacturer's recommendations - doubled during the wet and extreme tests.
The full testing protocol is documented here: https://zerofrictioncycling.com.au/...01/ZFC-Test-protocol-Full-Brief-v3-Jan-25.pdf
The results are on the web here: https://zerofrictioncycling.com.au/lubetesting/
And the full Excel document can be downloaded here: https://zerofrictioncycling.com.au/...0/Test-Main-DATA-Oct-25-website-upload-1.xlsx
Interestingly, BikeRumor.com has had articles on best bike lubes. Here's a video of the ZeroFrictionCycling guy reviewing that review:
He mostly agrees with the top picks, but points out, for instance, that Rock N’ Roll Gold is an "old" formula that was great in its day, but new formulations from other companies over the years have since have surpassed it. So, the lube that was better than many of its peers 15 years ago is now just middle of the pack.
The table shows the wear recorded across the main test (cumulative - each blocks wear added to all previous wear).
For most data / cost comparisons I use the first 5000km only, excluding harsh block 6, as most lubircants have failed long before, and I am using heavily extrapolated data to fill.
The main test up to the end of Block 5 (5000km of testing including a dry contamination block and a wet contamination block) - is an overall fairly tough test.
A lubricant with a result of 1.0 (one chain worn to the recommended chain wear replacement mark of 0.5% elongation wear) for Block 5 is a high performing lubricant
For MOST cyclists - especially predominantely dry conditions road cycling - you should also expect to attain at least 5000km to a 0.5% wear mark for that lubricant.
IF you ride predominantly offroad - you should refer to the individual block by block data table (below the cumulative wear table) to select a lubricant that performs well
in offroad conditions (gravel / mtb). Many wet lubricants especially become very abrasive very quickly when exposed to the world of dirt and dust.
IF you ride predominantly or frequently in wet condtions / harsh wet conditions - you should refer to the block by block data table (below cumulative wear table) to select
a lubricant that performs well in those conditions.
ZFC has also done a single application longetivity test, which may also be of interest to people who don't want to take the time to re-lube frequently.
Here's a link to BikeRumor's lube review:
Enjoy
I have zero reason to change
The Excel test data file has this note:
In summary - if you have been happy with a product that tests poorly in the ZFC test, you will be doing carthwheels of joy if you used a high performing product instead.
That said, Squirt does fairly well in the ZFC tests. In the video, BikeRumor gave it a "great value" rating, and the ZFC guy says (about 24 minutes in) that it's a "solid choice," but that it has "initial penetration issues" in that it doesn't readily sink into the pin/roller interface where it's really needed - but once it does it performs well. If you do use Squirt and ride in the wet, you should thoroughly clean and re-lube before riding again, especially in the dry afterwards. But, that re-lube will take a bit before the lube gets down where it's needed, and you'll get higher wear until then - but then it's great. So, a mixed bag depending on where you ride and how/when you re-lube.
FWIW, the top 15 ZFC rankings are:
Silca Hot Melt
Mspeedwax New Formula
Finish Line Halo IM wax (*RE-Test Jan 25)
Rex Black Diamond Wax - 11+1 mix
Rex Black Diamond Wax - 4+1 Mix
Silca + Endurance Chip - *Extended intervals*
Optimize Bike
Dynamic Wander Wax
Silca Hot wax X
Candle wax
Private Immersive wax (3)
Effetto Mariposa Flower power wax
Private immersive wax
Private immersive wax (2)
Ceramic Spd UFO Drip New Formula
And perhaps surprisingly, the Muc-Off brand varieties perform poorly.
I like how candle wax made it into the top ten.
I wonder how my candle wax spiked with Teflon powder would perform?
Silca Hot Melt
Optimize Bike
Dynamic Wander Wax
Silca Hot wax X
Candle wax
Well I'm a good 7000kms into my original chain and the Park Tool chain checker is very happy with it. Fingers crossed
