JFane
ChrisL
This is what you do to reset the Daylight
Stromer ST2 Day LED Setting
To the set the Daylight:
1. Set the bike on the main screen that has Lock, Off, Sensor, Move, Menu.
2. Pull and hold the right brake lever.
3. While holding the right brake lever, push the Menu icon.
4. While holding the a Menu icon, release the brake lever.
5. Continue holding the Menu icon until the screen automatically takes you to the MENU.
6. Scroll down to SERVICE and select it.
7. In SERVICE, select SETTINGS.
8. In SETTINGS, you’ll see DL AUTONOM. The setting should be OFF, so just press the OFF to change it to ON.
9. Press the On / Off switch underneath the top tube to exit this menu.
10. You’re done.
10. You’re done.
