tomjasz
- USA
- City
- Minnesnowta
Sorry fat fingers on an iPhone.You auto correct bungled the name.
I thought Juiced use MAC, not GMAC, unless it was modified?
Ah I see.
Also, that's not quite accurateHillEater was a Juiced Canadian distributor.
However, I believe they decided to stop selling Juiced and go on their own way.
The HillEater Galiano is based on eZee Primero GTS, not Juiced CrossCurrent.
Primero GTS - Ezee Bike
eZeebike Primero GTS Components: Frame Al alloy 6061 Suspension Fork Mozo Peak, 100 mm travel Handle Bar Al alloy 6601 Head stem Cold forged alloy, thread-less, adjustable Head set Sealed bearing Tapered 44/56 Seat post...continue readingezeebike.com
Been playing with the idea of building a GMAC based bike, using a RAD Rover as a donor bike (1500.). No, it doesn't have all the high end components, but it's proven itself as a fairly reliable package with a decent battery, which is all I care about.
The Grin GMAC drive and necessary components (controller, display, laced up wheel, etc.) add up to about 1200. The components you remove from the new RAD are worth at least 500. That's what I got for the 'City components when I installed a "kit" on that bike. I'm figuring I could have this bike built, with street tires and suspension seat post for less than 2500 complete - an easy DIY conversion.
Bigger point is, the Grin conversion kit is pretty reasonably priced when considering the variable brake/regen and performance potential. Add YOUR favorite donor bike, and it's not hard to come up with a pretty economical performance bike.... I see one in my future, soon!
Also what is it like to ride an ebike with a Gmac powering it because of the regeneration?
If talking GMAC, Grin would likely be the person to talk to about trimming adjustments to your tastes.Thanks for the info, wonder if @pushkar can work on the t sensor for improved response if needed
Hmm okay maybe I misunderstood something?
When you said you want a GMAC, I thought you were looking for high performance.
To get a most out of GMAC, you would want a high drain rate battery.
If you just need a little more boost, without changing too much on Rad Rover, I think Bolton kit would be the best bet.
Somebody on this forum (Feliz or Dewey) said that he got a Bolton kit, without upgrading the motor to Bolton 750W (retained the stock Rad 350W motor), he still saw a significant gain in performance.
I don't know.. when I hear people wanting a GMAC or Bafang Ultra, almost always they're looking for performance gains.
But if you're interested in GMAC just because of their built quality and whatnot, I can understand that too.
