Alaskan
I can report, based on my riding this bike when it came new back in mid 2018 with the Fox Performance upgrade and the 80mm travel on the fork. I put about 2,000 miles on the 2018 before passing it along to Nancy, selling her Nevo Nuvinci and buying a 2018 for my use. I did upgrade Nancy's 2018 Homage Rohloff HS to the E-14 electronic shifting. The ride quality and the ability to tune via air pressure and rebound control is definitely superior in the Fox fork and shock, particularly the shock as the xFusion has a tiny air capacity and is difficult to get dialed in to the correct pressure, at least by comparison.. The base stock suspension on the 2018 with the Suntour Aion fork and Xfusion shock was good not great. That's why I swapped it out when we were both riding Homages. I ride 4-6 days per week, weather permitting. Nancy rides with me every week or two.Jay, Still awaiting the needed parts. Once they are installed and Nancy has had a chance to ride and form some impressions, I will report back.
It will be interesting to see how the Fox fork works on the 2018 bike as it has non-boost 100mmx15mm hubs and a 28" rim. I plan on installing it on the 2018 using a boost adaptor kit that includes two 5mm spacers that sit on either side of the hub on the axle as well as a 5mm ring with six bolt holes that offset and align the brake rotor with the caliper. If this creates any issues I will have a 110mm boost hub laced in to the exiting wheel.
It will be interesting to see how well it works as the shock off of my Delite Mountain is a Fox Performance with 100mm of travel, adding 20mm to what the bike came with. I sure hope that 20mm does not mess up the bike's steering geometry. A Nancy is a relative lightweight at 130lbs. With the shock air pressure set around 65-70, it may sag enough to make the difference negligible and the extra 20mm may be enough to adjust for a really cushy ride without the risk of bottoming out the shocks.
