tcombest
I’ve put about 200 miles on my new 1100. The slicks are very fast and light for road riding.  And I have no problem with them.  But I like big knarly knobby tires. I decided to upgrade to Maxxis Minion exo TR tires, set up tubeless. Two tubes and two Mr. Tuffys weigh over 3lbs. On my 2019 hyperfat 1100, I put a 4.8 on the front and a 4.0 on the rear. The double wall rims are great for going tubeless. The spokes are somewhat inset. You can trim excess off the rim strip to allow more tape contact. 2 3/4 gorilla black tape fits perfect in the rim. I taped over the rim strip. A 4.8 (actually 4.5) will just fit on the front. It will NOT fit on the back. You will lose 3 gears. The 4.0 (actually 4.1) fits great on back and you lose no gears. The beads on these TR minions seat up very easily going tubeless. Don’t try tubeless with the non-TR 4.8 minions. It is a nightmare. Bead diameter is way too wide.  I am converting my Ripcurrent S tomorrow to the same setup. I’ll try and get a video up on YouTube. The RCS is easier because you can unplug and remove the rear wheel. The HF1100 has a heat shrink wrapped plug that you don’t want to cut/remove. There are actually 3 wires under that heat shrink and they are also heat shrinked. Flip your bike upside down. Set a cooler or bench next to the bike. Cut the 3 zip ties on the power cable to give you some cable room. You can remove the tire and set it on the bench to change the tire while the power cable is still intact. This tubeless conversion with these tires works very easy and is a nice setup. It’s easy to reattach the cable with zip ties.
Ok, I did a pretty crummy job of making a video of the tubeless process, but it does have some good info in it. The link is in a post below...
