themongooseman
- New Zealand
They are indeed. It’s exactly the same unit.I’ve been told by Ridercare that the extenders are compatible.
Thanks, mschwett— that was a helpful analysis! I didn’t really understand the FutureShock difference nor that Rival was that much better than Apex. Food for thought!
I’m ordering that very upgrade shortly.You can also upgrade the future shock on the Comp model to the 3.3 system if you want.
The units are identical but you have to ensure the firmware on the battery is latest spec. I plugged mine in that was not and I did not get full power. Got Specialized to flash it the following day and full power was backBy the way, are the Creo SL range extenders compatible with the Creo 2? The Specialized website does not list Creo 2 as a compatible model for the RE battery.
I did consider the Future shock 3.3, but can honestly say the 3.1 on the comp is excellent. I have had the 1.0 on the Roubaix, the 2.0 on the Creo 1 and now the 3.1 and can honestly say the 3.1 is the best. The 2.0 was adjustable, but I never used it. Hardly notice the 3.1, which is exactly as it should be and I love the fact they is virtually zero bottom out on it, hence not feeling it.This mirrors my experience. I chose the Comp because the Apex components are functionally identical to Rival, and a whole lot cheaper to replace. I’ll be adding the Futureshock 3.3, the range extender and a better wheelset in due course (I’ll almost certainly go Enve for their incredible warranty, but I’m open to Rovals as they were awesome on my last S-Works bike). I also love the colour. At this point barring a few very minor things it’s equivalent to the S-Works trim for over a third less (the S-Works also only comes in black, which holds zero attraction for me).
That is amazing that the battery needed a firmware to work with the Creo 2! Did you have to bring it to a Spesh dealer to update it? An online store is selling ‘new’ extender batteries on eBay for $349, but I’m a little wary.The units are identical but you have to ensure the firmware on the battery is latest spec. I plugged mine in that was not and I did not get full power. Got Specialized to flash it the following day and full power was back
My RE was purchased with my Creo 1 a good few years back and I did not get the firmware updated. Yes a quick trip to Specialized dealer and they flashed it in 5 mins. It is the same with Creo 1 and Levo main batteries. These do work with Creo 2 but need to on the latest firmware. I have see a post in the Levo forums where a chap had pop in an old battery and not got full power, so when my RE had the same issue, it was my first and correct thought. Spec app will show the firmware version, but no issue if it does need updating, provided you are close to dealerThat is amazing that the battery needed a firmware to work with the Creo 2! Did you have to bring it to a Spesh dealer to update it? An online store is selling ‘new’ extender batteries on eBay for $349, but I’m a little wary.
Thanks, Dazman- all this stuff is good to know!My RE was purchased with my Creo 1 a good few years back and I did not get the firmware updated. Yes a quick trip to Specialized dealer and they flashed it in 5 mins. It is the same with Creo 1 and Levo main batteries. These do work with Creo 2 but need to on the latest firmware. I have see a post in the Levo forums where a chap had pop in an old battery and not got full power, so when my RE had the same issue, it was my first and correct thought. Spec app will show the firmware version, but no issue if it does need updating, provided you are close to dealer
Don't you need to bring the battery and the Creo 2 to update the Range Extender? My Range Extenders were updated on the e-bike.My RE was purchased with my Creo 1 a good few years back and I did not get the firmware updated. Yes a quick trip to Specialized dealer and they flashed it in 5 mins. It is the same with Creo 1 and Levo main batteries. These do work with Creo 2 but need to on the latest firmware. I have see a post in the Levo forums where a chap had pop in an old battery and not got full power, so when my RE had the same issue, it was my first and correct thought. Spec app will show the firmware version, but no issue if it does need updating, provided you are close to dealer
It could be legit. That was the RE price with the U.S. discount this year. SAn online store is selling ‘new’ extender batteries on eBay for $349, but I’m a little wary.
I took the just the RE in with me. I did have the bike in car boot, but they just updated the RE.Don't you need to bring the battery and the Creo 2 to update the Range Extender? My Range Extenders were updated on the e-bike.
Good to know!I took the just the RE in with me. I did have the bike in car boot, but they just updated the RE.
Specifics of how it does so would be rather more helpful than a no-detail counterpoint.It absolutely does.
yep, directly orderable in the US at least.You can also upgrade the future shock on the Comp model to the 3.3 system if you want.
Anything you can do to lower your centre of gravity over loose ground helps; it’s also useful just to make sure the seat is low enough not to continually punch you in the balls over rougher stuff. Would I prefer it to be a longer drop? Probably. Does it still help? Yes.Specifics of how it does so would be rather more helpful than a no-detail counterpoint.
What specifically can you accomplish by dropping the seat a whole 50mm? It doesn’t appear to be enough movement to let me clear the seat to get down behind it on my M size frame
Look forward to hearing about your experience with it. Happy New Year!You can call me crazy.... I´ve sold my Creo 2 Expert.
Now I´m waiting for my S-Works Creo 2![]()
Was this returned to Specialized under the 30 day policy, by chance?You can call me crazy.... I´ve sold my Creo 2 Expert.
No, sold to another now really happy owner.Was this returned to Specialized under the 30 day policy, by chance?
Lol - You are crazy. Cheapest I have seen in Europe is Bikeinn who had £700 odd off the S-Works. I agree the S-Works is a fine machine, but given the Carbon Comp is less than half the price I would use the £6500 saving to purchase the exact parts that I needed to make the perfect bike. This is what I have done with mine and I am still cheaper the the Expert modelYou can call me crazy.... I´ve sold my Creo 2 Expert.
