Frey Hunter/ Bafang Ultra- replacement crank arms
Escoozeh
I have a Frey Hunter with what I believe are the stock 170mm crank arms on the Bafang Ultra. I'd like to get shorter cranks to reduce pedal stroke.
Anyone know how I could figure out which arms would be compatible? I believe the Ultra uses ISIS style arms? I believe the only other thing I need to pay attention to is Q-factor for clearance. Is this correct?
These will probably work:
I've successfully installed them on an ultra equipped ultra Eagle that also came with the original Bafang arms, so you should have no problem with chainstay clearance.
  • Like
Reactions: JRA
