Discussion on Chainstay length on X2
IOUZIP
I have been researching chainstay length and how it affects the bike. I am no expert and just started to read about the different ebike chainstay lengths. The Luna X2 has a really long 458mm length which by design helps keep it steady at higher speeds. That got me researching the other manufacturers chainstay lengths. 444mm or close to that seems to be the norm for full power ebikes. The position of the motor and the rear link length also play a role in determining the final length. Shorter chainstay lengths help control around tight turns. 29 in wheel in the rear usually moves the chainstay length out to accomodate the larger wheel. I will say my X2 does not loop out very easily on hill climbs.
Yes your correct shorter chain stay means tighter turning radius.
Not sure what "does not loop out" means.
Longer wheelbase means more stability at speed. Check out some downhill bikes the last thing they want is a wobble at speed.
Been riding for a couple years now a 27.5" in the rear and a 29" in the front and that works really good for all my riding.
Took a few rides getting used to the slow cornering in tight confines using a 29'r in the front. A bit twitchy, if you have the same set-up you know what I'm talkin about.
The X2 looks like a good ride.
