got the Wera socket set for Christmas. not too much for bikes, more for the house. But it's a great setup. The socket head swivels and locks works as a screwdriver too. The case is great the sockets twist out so they are easy to remove, and there is Velcro on the back so you can stick it somewhere.
View attachment 203794View attachment 203795View attachment 203796View attachment 203797
Over the last few years, I have changed all my tools to Wera, where I can as they are excellent quality.
For pliers and suchlike, I’ve charged over to Knippex.
No old tools were harmed in this exercise and were donated to the local “Men in Sheds”.
DG…
I haven't yet needed this spreader for brake pads, but it was just the tool to pop the cover off my Radmission motor to dispel my misconception that it was direct drive.
I have been using custom cut utility poly pipe that is cut to size and heat molded to the chain stay. It quiets stuff down and is fairly self lubricating.
I haven't had that problem, but the chain on my Radmission kept smudging my right pants cuff. I used a heat gun to bend a piece of polyethylene garden edging into a guard to cover 11cm of chain.
I installed a faucet with a pull-down sprayer on the bathroom sink so I could rinse soap off my face without getting my clothes wet. In the confined space below the sink, the retractor weight kept hanging up, leaving the nozzle dangling. A chute fixed that. I made it by sawing a section of 3" poly pipe lengthwise.
I made a pot seed picker-upper tool.
I bought a "Bead Tweezers" for jewelry, but it was way too big for a pot seed,..
So I custom built my own bean Tweezers.
I had to use all the dentistry skills that I could muster up. 😁
It works Great!!!
The seeds are $10 each, and it sucked to have them fling off into the abyss when they'd slip outta the regular Tweezers.
I found out that a regular 18650 lithium cell fits inside my LED flashlight,..
The springs are long enough to accommodate both a Lithium Cell or the shorter, fatter AAA battery adapter.
I don't ride anywhere without this tool. This morning I stopped to use it only 300 yards from my driveway. As usual, there was no emergency. I did it to flirt. A beautiful automobilist did likewise.
To paraphrase a line about Robert Mitchum in "Thunder Road" .... "Nobody can compete with him. He's got the loudest horns in the valley."
This bulb makes my clarinet horn as loud as my saxophone horn, though neither can match my boat horn.
I was installing some brakes today when the new and unusual pads took a direct hit of mineral oil. I washed them off with a bunch of Dawn water. Then I soaked them in some gin. Then I took them outside and hit them with automotive brake cleaner then I lit them on fire. Sanded them and lit them on fire again. They were saved. The gin did not have an olive.
... but don't take it outside, hit it with automotive brake cleaner, light it on fire, or sand it. Don't ask how I know!
That reminds me of a joke where a guy put a towel over himself to hide wood. A girl asked him what was under there and he said my bird and he fell asleep on the beach. The bald one eyed bird was so ugly she smashed its nest and eggs then set it on fire.
Here's a handy one I made from a $12 Harbor Freight welding clamp. It's not specifically a bike tool, but is comes in handy when working with those pesky slide barrel quick connectors used on air hoses, pressure washers and hydraulic hoses. They often get pressure bound or stuck from grit getting into the slide.
Takes just a couple of minutes with an angle grinder to open up the jaws to fit the notch in the coupler barrel:
View attachment 207972 View attachment 207973 View attachment 207974
You can also pinch the backside of a fat tire while you work the other side.
I made a long jaw caliper to measure Fat Tires using a regular caliper and two Bic Razor handles because I didn't want to spend $25 for the long jaw version. 😁
It's digital, so you can zero it wherever you need it.
Just gotta keep the jaws parallel when you glue them on.
I use this one for that:
I've got the Vice-Grip version of that tool.
I use it ALL The Time !!!
It's from the days before Vise-Grip sold their name to China, so its not a POS.
This thing is a Real POS !!!
I wanna just throw it out, but it was about $20.
I did throw out a $30 Vise-Grip geared tin snips.
My $4 non-geared "pruner" from the dollar store actually works better.
A Lot Better !!!
so instead of a couple sticks and a tape measure you bought this? hellthe mark 1 eyeball and a tape measure is plenty.
I was trying to see if my Bafang hub drive motor had the same dimensions as my unlabeled Das-Kit hub motor without despoking each motor to take measurements.
A bent piece of solid house wiring, or a coat hanger kinda worked, but my homemade long reach caliper was a bit more accurate. 😁
Popsicle sticks would have worked OK, but they're kinda thin and bendy. 😁
