since you never pedal this tool is pretty worthless to you. you can get the same results sticking your finger in there :D
I am in the process of adding a BBS02B mid-drive to my hub-drive, so my chain and sprockets are going to start seeing some use.
I've already upgraded my freewheel and I bought a KMC ebike rated chain to replace my "Z" rated KMC chain.
I was gunna cheap out and buy a "Z" chain, but I couldn't find one long enough, and I didn't want to join two together.
(I actually had the "Z" chain in my cart then figured that I should count the links on my chain first.
It's a good thing that I can count past 100 😁)
It should be here in a couple weeks.
I might actually get it up and running before the first snowstorm. 😁
I was thinking about switching the freewheel for a cassette that doesn't ratchet.
I don't need the cassette or freewheel to ratchet because the BBS02B chainring ratchets, so the chain would keep moving, and I could change gears without pedaling.
But there's too much drag on the chainring clutch, and that would affect my range too much, so I'm gunna have to start pedaling, but only to shift gears.
that's what gets me on a lot of ebike commercials,people that have never missed a meal,throttling their ebikes or trikes,never turning the pedals[ while greasy Joan,doth keel the pot]
[And Dick the shepherd blows his nail]
They're never shown in ski gloves.
[And Tom bears logs into the hall]
How come they're never shown with a load of logs? Do they have Amazon deliver their firewood?
[And Marian's nose looks red and raw]
They never wear hats with extended bills to keep the sun off their nose.
"to whit,to whit"! forgive my Shakespeare please.( disclaimer.most healthy .happy people you see on "pharma commercials" are actors-except for the goofy animations( thought Kennedy ,Jr was supposed to do away with pharma commercials)
I often put lights on helmets. Two of these are close motion activated. You move through modes such as solid to strobe by waving your hand. The ones on the ends are epoxied on. The middle one is attached by rubber straps. The one on the left is removable with the visor. What is great is that the light moves to where you are looking, like at a driver while entering a crosswalk. I also use fixed lights on bike. This is supplemental.
The new kind of low-end headlamp impresses me. No colored lights. Just wide high, wide low, spot high, and spot low. The wide bar is intense enough to be conspicuous in the sun but I think not too intense to look at a driver at night.
If you hold the button a few seconds, the spot and wide strobe rapidly together, and it's intense 100 yards away in the sun. The original strap won't go around a helmet, so I wear my Richardson 112 Original Trucker cap to flash the beautiful lady down the street. She must be pretty thrilled because she flashes me with her headlights. Of course she doesn't let the public see her face when she does that.
View attachment 211618View attachment 211619
I have lights epoxied to my helmets. One is on a removable visor. One has a motion sensor to select modes. You just wave your hand in front of it. I love the classic horn. What is so great about them is that they put a smile on people's faces. It is not just saying Hey, get out of my way. It has whimsy.
I've been having nightmares since I substituted two short bars for one long one. The streets are awash, and in the heavy rain I don't see Pennywise until the prow of his yacht is looming over me. Clowns laugh at clown horns, and a Bombay taxi horn probably wouldn't daunt Pennywise. In my dream I reach for the plunger of my boat horn, but it's not there because there wasn't space to mount it. I'm up the creek without a paddle.
The two smaller horns might not even honk. IMHO, the tariff on miniature power tools is too low. With modern tools, it doesn't take a carpenter bee long to plug those horns. The boat horn has never failed. I guess bees find it intimidating or the color disagreeable.
If I knew where to get a long stem, I could mount a third handlebar for my boat horn.
I've been having nightmares since I substituted two short bars for one long one. The streets are awash, and in the heavy rain I don't see Pennywise until the prow of his yacht is looming over me. Clowns laugh at clown horns, and a Bombay taxi horn probably wouldn't daunt Pennywise. In my dream I reach for the plunger of my boat horn, but it's not there because there wasn't space to mount it. I''m up the creek without a paddle.
You could get an accessory extender.
Ordered. Now I can mount a tire pressure monitor. I'm sure you know how embarrassing it is to be pedaling along and have the highway patrol pull you over to let you know you have a flat tire.
Interesting idea though. If the TPM system were compact enough, I might try it on my bars. I would like to know my tire pressure without having to use a gauge. It could tell you in advance if you have a slow leak and give you time to react before it went completely flat.
This one from Amazon is cheap enough but it isn't very well reviewed:
When I had the Radrunner I would have bought one because tire pressure was a hassle compared to my motorcycle. To reduce the danger of blowouts, BMW had gone to natural rubber tubes, and they were porous. Checking was just a matter of a couple of zigzags on my first hundred feet of pavement. If either tire was 10% low, I could feel it. I'd stop and add air. The weight of the bike made it easy to get the gauge and the pump on and off without losing air.
With the Radrunner, I might not know a tire was low until it was down by half, but when I pumped it back up, there was a big improvement. With a bicycle, it was hard to get a chuck on or off without losing air. Subsequently, the tires on my Radmission and my Abound let me feel when they're down by 10%. Better chucks help me connect and disconnect without losing air. I used to hate to get down to check or inflate tires, but in the last year or so, I seem to be spryer. I don't know why.
Inflating tires meant kneeling or sitting on concrete, gravel, or grass. PVC mats make a huge difference.
I bought two in 2022 to put on carpets just inside doors. They didn't stay put, which meant they didn't keep the carpets clean, and when they slid, would become hazardous by rippling up. It took a couple of years to dawn on me to get rid of them. I put them on the concrete porch. When I had to work on a bike on a rainy day, I realized that the 3x4 would be good to lay the bike on, and the 2x3 would be good for kneeling or sitting. Besides other advantages, a mat like this will keep a dropped screw from bouncing far and make it easy to spot. I can take the smaller mat to check tires.
I don't like sitting on the ground or kneeling to check tire pressure either. That's one of the reasons a TPM system is so attractive to me.
Now, I check the tires while the bike is still on the rack. That way the valves are at eye level. No help if the bike is already on the ground though.
I came across this one from Sram that is highly rated:
A bit pricey though at $130. I'm also concerned about its size & weight. Might cause tire balance issues and its more likely to get snagged on something.
