I don't like sitting on the ground or kneeling to check tire pressure either. That's one of the reasons a TPM system is so attractive to me.
Now, I check the tires while the bike is still on the rack. That way the valves are at eye level. No help if the bike is already on the ground though.
I came across this one from Sram that is highly rated:
A bit pricey though at $130. I'm also concerned about its size & weight. Might cause tire balance issues and its more likely to get snagged on something.
Expensive for what it does and you'll probably need to replace the battery every 6 months at best.
You also need specific legnth valve stems so it might be problematic getting a proper fit with tubed tires
Interesting, but I'm a pass.
I check my tires when I do a chain lube @300mi (2 - 4 weeks) and it's in the hoist at that point so easy/peasy
