I don't like sitting on the ground or kneeling to check tire pressure either. That's one of the reasons a TPM system is so attractive to me.
Now, I check the tires while the bike is still on the rack. That way the valves are at eye level. No help if the bike is already on the ground though.
I came across this one from Sram that is highly rated:
A bit pricey though at $130. I'm also concerned about its size & weight. Might cause tire balance issues and its more likely to get snagged on something.
Expensive for what it does and you'll probably need to replace the battery every 6 months at best.
You also need specific legnth valve stems so it might be problematic getting a proper fit with tubed tires
Interesting, but I'm a pass.
I check my tires when I do a chain lube @300mi (2 - 4 weeks) and it's in the hoist at that point so easy/peasy
I either pinch the tire or bounce the bike. every tire brand model is different though so it takes practice.
I can just bounce a tool on a tire such as a pedal wrench. There is a tone and resonance. There is a app for Gates belts that works in a similar way. It checks the note, but if you have an ear you can hear it. Many wheel builders also use the tone of spokes by plucking them.
For a long time, I was thinking of putting planks on stacked cement blocks so I could roll a bike up onto the platform to check tire pressure.
I've been a fan of Carl August Norgren's ball chuck since shortly after his passing.
"I cannot help but wonder
how I can careless be
of the swiftly passing moments
that see oblivion's sea;
methinks then how much better
to improve them as they flee.
Though I live but for a moment
my deeds.... eternity."
A chuck for a Schrader valve is supposed to have a rubber washer will seal at the rim, then compress to let the chuck push the valve core open. The problem was that a washer soft enough to seal and then compress, wouldn't last long. Norgren solved that in 1927 with his ball chuck. It worked very well for me on cars, trucks, and farm equipment, but a bicycle wheel could move as I pressed the chuck onto the valve, and a little air loss from a bike tire can make a big difference.
It seemed to me that the solution for a bicycle wheel was to position the valve at 6 o'clock so it wouldn't move when I pressed a ball chuck onto it. That required me to get on the ground. I could still lose air. That's when I thought about the statue on Norgren's grave. It's a gentleman defecating. He represents the manufacturers who, since his patent expired in 1944, have flooded markets with substandard ball chucks.
So I bought a rechargeable pump that included a good gauge, so one connection could both check and inflate. I bought a longer hose so I could lay the pump on the ground as I held the bike with one hand to seat the chuck with the other. I tried different ball chucks. I found one that always sealed, but sometimes the washer didn't compress enough to open the Schrader valve. Each time that happened, I 'd rub the washer in circles on wet sandpaper. Eventually, that solved the problem. Now I can check and pump tires while standing. I may sit or kneel on the ground for other tasks.
F
Ya I remember those days. Now with the click valve I just snap it on and pump away. you know its on and no leakage
Why are 37, 622 tires the same as 35x700C?
why are there so many different kinds of USB and access points in Americas electronics? I hear Europe standardized on USB C why cant America do the same and all those freakin battery sizes plus the auto headlights these days,back in the day "Cibies" were illegal in america I believe perhaps there are too many cars on American streets( forgive the text my laptop took a crap)
For eight years my good friend has purchased one or two bikes per year. He always gets the most complicated hodge podge of bikes designed by marketing departments and he is always disappointed. He falls for stuff like electronic shifting on a hub-drive. Now he is looking at a duel battery carbon frame bike with a torque sensing mid-drive and has a throttle. The gears are the same as the junkiest of fat folders. The batteries and the motor are proprietary to this bike only. The company has no location and there is no dealer support. It has a name that cannot be pronounced in English. He expects me to make house calls to repair them.
I went for a ride to get a burger. I sat with a couple of painters working there today. After they ate they setup to paint the rails around the tables. One of the painters put on rubber glove and then a cotton glove over it. He put his hand it the paint and rubbed it down the rails and did an entire section in a couple of minutes.
As I was writing that my friend emailed. After my warnings, he is getting that dual battery, carbon bike. He wants to take the chance because a video hyped it by a YouTube influencer. Actually it is a hub-drive that has black panels on either side of the cranks. And it is a 'Class 3' that goes 25 with the throttle. You will never be able to replace the seatpost battery.
I guy brought in a carbon MTB late yesterday for a bleed. This morning I removed the rear pads, put a block between the pistons and planned to attach a lower syringe and use an upper Shimano reservoir. But the lever plug had been over tightened with a torx and it takes a 2.5 mm hex. The fork is also backwards. See how the hose is routed. And the lever reservoir on the front is also stripped!
I have seen a few cheap bikes with forks on backwards.
That's an end user fail...
All bikes ship with the handlebars not installed.
I suspect he had his nephew installed the upgraded forks and do a top bleed after watching a video. Now here is more like what @Gionnirocket is talking about. The handlebar is upside down and backwards from livingroom assembly. At least the saddle looks good.
Dual kickstand and dual controllers. This is one of the worst ever. I wouldn't ride it with a bag on my head, if I were paid. It already is set-up for through frame. Why not use that.
In contrast see this eBike.
I have an old gas lift office chair in the bike room and with the valves up top it's an easy job to check them. I have a little 12V car pump and gel-cell batt in an ice cream bucket there too so pumping them up is as simple as screwing on the adapter and then the hose. Why people use hand pumps is a head scratcher to me. For one bike sure, but not when you have several. As for getting on the ground, sure that can be a little testy as you age but it's all exercise and stretching stuff.
Use it or you'll lose it.
A bungee cord is better than a second kickstand. If the fork won't turn and neither will the front wheel, it's more secure on the sidestand, or I can lean it against something. It helps if I need it to be stable for mechanical work.
It also prevents theft, unless a truly professional thief brings an angle grinder with a wheel designed to cut bungee cords!
