since you never pedal this tool is pretty worthless to you. you can get the same results sticking your finger in there :D
I am in the process of adding a BBS02B mid-drive to my hub-drive, so my chain and sprockets are going to start seeing some use.
I've already upgraded my freewheel and I bought a KMC ebike rated chain to replace my "Z" rated KMC chain.
I was gunna cheap out and buy a "Z" chain, but I couldn't find one long enough, and I didn't want to join two together.
(I actually had the "Z" chain in my cart then figured that I should count the links on my chain first.
It's a good thing that I can count past 100 😁)
It should be here in a couple weeks.
I might actually get it up and running before the first snowstorm. 😁
I was thinking about switching the freewheel for a cassette that doesn't ratchet.
I don't need the cassette or freewheel to ratchet because the BBS02B chainring ratchets, so the chain would keep moving, and I could change gears without pedaling.
But there's too much drag on the chainring clutch, and that would affect my range too much, so I'm gunna have to start pedaling, but only to shift gears.
