This is from the e-bike RAW data. I could of course add the markers. Why not?That's a computer generated graph.
It's too square and chunky and all the spikes are evenly spaced.
It's a list of samples and averages.
In the end, cell resistance(and resulting sag) is what defines the life of a battery (assuming no individual cells have died yet)
Sorry but that is not raw data at least in the engineering sense but interpolated data over time. Raw data would occur at something like 60Hz (or higher) meaning there would be thousands of values. Simple computer sampling theory.This is from the e-bike RAW data. I could of course add the markers. Why not?
Battery Voltage On A Ride As Function of Battery Percentage.
Criteria for the graph:
-- Coasting filtered out
-- Single Assistance Level (Eco)
Unlike hub-drive motors, mid-drives operate with variable power. It makes all the voltage sag discussion irrelevant. (It is noteworthy the motor could draw even 280+ W at the 12% of the battery charge. Note the voltage was pretty low at that battery %).
I havnt looked into it much so Im definately not the expert on cell failure, especially when charging.Can you explain to me how a bad cell can lead to a fire?
I assume it becomes overcharged then gets hot?
What you are saying here is a pure sophistry (translated to Simple English: Bullshit).Sorry but that is not raw data at least in the engineering sense but interpolated data over time. Raw data would occur at something like 60Hz (or higher) meaning there would be thousands of values. Simple computer sampling theory.
Most likely, it keeps track of voltage when not supplying power and averages that over time. If advanced, it could determine cell resistance based off voltage at various loads, in any sense it would still be averaged.
All this can be found in the TSDZ2 open source software code, I doubt specialized/brose has gotten around well understood physics
Your last statement is completely false and actually moreso on your(and mine) 36V bike compared to most chinese 48V systems.
Voltage sag under load is identical for my BBSHD, GMAC and DD motors using the same battery under the same load
That being said, I am concerned about failure that can occur due to shorted cells.
Are you trying to tell me your voltmeter gives your eyes the sampling frequency of 60 Hz? Ha. Ha. Ha.
An industrial Distributed Control System (DCS) has a resolution (sampling frequency) of 1 s. The sampling frequency of the Specialized system is 1 s, too. It seems you know very little of Measurement & Control.
Are you actually trying to imply that all sampling in the world occurs at 1Hz. Thats an insane and completely false claim. I have worked in the embedded software industry for well over 35 years including avionics flight controls, measurement, test, simulation and most recently spacecraft attitude and control.What you are saying here is a pure sophistry (translated to Simple English: Bullshit).
Its pretty common knowledge in the RC industry that 18650 cells shouldnt be totally discharged in less that 1/2 hour due to their high internal resistance.Your graphs aren't showing every 1 second sample.
I count about 90 dots on your red graph.
You didn't drain a fully charged battery to 10% in a minute and a half.
Most likely, the data being shown while sampled at 1Hz(by the app) is sampled at higher frequencies within the embedded firmware within the motor and then averaged according to some criteria (of which I have mentioned previously). That data (before being averaged) is what is considered RAW data in any engineering discipline.If you hooked up a voltmeter directly to your battery you would see the real time voltage as it is happening, not what the computer decides to show you on a screen.
I assume a bad cell is more inclined to overheat?When a cell overheats it overrides the "vent" so to speak and it cascades very quickly, oft times taking the rest with it
Interestingly on a pack that had a bad cell and required disposal, I disassembled it to individual cells and discharged each one with a small automotive light bulb.When a cell overheats it overrides the "vent" so to speak and it cascades very quickly, oft times taking the rest with it
My whole point was the voltmeter was not needed at all for a high quality mid-drive motor e-bike. All you need is a reliable battery %, possibly Wh remaining in the battery, and maybe the W/km (or mile) data field. The new Specialized Mastermind e-bikes have all such data available for display, including a reliable Range Remaining and Range Trend (that is, whether you are losing or gaining Range depending on the current ride conditions). Add to it MicroTune (adjusting the assistance in small increments as you ride) and Smart Control (ensure you will make your ride goal still with the battery charge), and it is more than most e-bikes can provide. For a practical cyclist, the Cadence and Rider's Power fields are extremely important, and not found on many e-bikes.Most likely, the data being shown while sampled at 1Hz(by the app) is sampled at higher frequencies within the embedded firmware within the motor and then averaged according to some criteria (of which I have mentioned previously). That data (before being averaged) is what is considered RAW data in any engineering discipline.
I cant believe we are even debating this![]()
Now, could you show me similar charts to what I showed before? Or, you are just tawking?![]()
I own onenah, you just need a light bike that rides well so it's fine if the battery is flat.
