Moving Away From Heavy E-Bikes
My whole point was the voltmeter was not needed at all for a high quality mid-drive motor e-bike.
My whole point was that a voltmeter is all that you need to monitor ANY battery on ANY ebike.
Or any battery at all for that matter.
An Duracell AA battery in your flashlight, a car battery, or any rechargeable battery of any kind.
Lipo, NiCad, NI-MH, SLA or a lemon with a zinc nail and copper wire stuck in it.
If you know the parameters of the battery and how to watch the voltmeter, you can assess the condition of the battery.
I personally would rather make that assessment myself, and not be told by a computer what it thinks I aught to know.
How do you apply the voltmeter on any of my batteries that use the "WAKE UP" pin?
Why should I use a voltmeter on my e-bikes if they measure the voltage themselves?
Why should I use a voltmeter if my e-bikes tell me the battery condition precisely?
This is as if you bought a power-meter pedal for your hub-drive e-bike and were telling me: "See? How fantastic! Now I can measure my pedalling power" to which I would just smile and say "Pal, my e-bike has the cadence and power meters as the part of the motor" :)
P.S. I owned a multimeter and hardly ever used it. No need.
If you have the ability to interpret it, the raw data is more reliable than a manufacturers figures in %.
I'm sure you've noticed, eg, that the last 8% on the specialized disappears a lot quicker than the first 8% ? Or you can " drain " the battery then switch it off and restart with another 3% .
Or a 5 year old "100% charged" battery holds less wh / has less range than a new one despite being "97% healthy"
Why does your battery go to sleep completely dead then wake up with 3% charge?
What is the truth?
Is it dead or does it have 3% left?
The raw data is the truth.
What is the truth?
The Specialized system prevents the battery charge drop below 5%. That is, the assistance is cut off and the remaining charge is used to keep the lighting and the control unit on. Therefore, the problem you mention does not occur.
Show me the graph of the motor power in the function of the battery charge % please. Not interested in the voltmeter. As rude as it might sound, using the voltmeter and expressing the battery capacity in Ah (instead of Wh) are the "poor man things".
You did not answer my question how you measure the voltage of the battery with the "WAKE UP" pin.
I don't know how your battery works.
My battery doesn't have a wakeup pin.
If it did, I would delete it and wake it up manually.
The poor man's way.
You wouldn't measure the wake up pin on the battery.
You would measure the input from the controller to the wake up pin.
That is probably not a simple voltage but some kind of data signal that would have to be analyzed by a computer or oscilloscope.
Then you would make a signal emulator to feed into the wake up pin to wake up your battery.
I personally hate computers and would delete everything and put the battery to sleep when I choose, and wake it up when I choose.
I have chosen to put my battery to sleep at 42 volts.
If I really need more battery power, I can lower the nap time voltage to 39 volts so my battery can get a good nights sleep after I get home.
PCebiker: I just dream you buy an advanced e-bike and start meddling with it :D
I don't want an advanced ebike.
An ebike completely controlled by computers is to much trouble to figure out.
My dream ebike would be nothing more than a motor, a battery and a big ole rheostat controlled by a cable operated twist throttle.
The only computerization I would want would be inside the battery to monitor it only for safety.
I don't want a battery fire.
Why can't they build a battery with a thermal fuse or temperature sensor on every cell inside, so a bad cell can't hide?
Is the extra $10 in parts too much to spend on a $800 battery?
It's been there already. 1931,
I Like It !!!
I Wanna Gits Me One Of Those !!!
I really like the caster/rake angle too !!
Long well supported steering tube.
And a cover on the clutch gears, so it doesn't pull your leg in and rip it off.
I would just upgrade the battery to smaller lighter lithium cells...
I'm hoping all the R&D going into electric cars will yield big improvements in battery technology, allowing for a lightweight ebike at a reasonable price. Right now, there are ebikes that are pretty light, but boy are they expensive.
Yeah, I hope so, too! As for R&D, I dunno... from an engineering standpoint, it seems to me that there is no good reason there couldn't be a simple, off-the-shelf FS eMTB (with a simple motor like the E5000, hopefully a hair more efficient) that weighs 42 pounds. If I can shave a 49 pound down to 46 as easily as I did, it should be possible.
Not to get too hung up on the app issue, the other problem with apps, at least in the US, is that they are too invasive. I hate being targeted by anyone for anything, the information that is collected is always abused. I can see that if I lived somewhere else, maybe was younger, or had different social needs, the app could be a cool way to meet and keep in touch with people. And I'm glad Stefan is keeping up with members of EBR who have left the board-- I may even know who he's talking about, good guy!
In the current state of play? Not worth it to me. I value my privacy.
I made a couple of fat boys last season. The Specialized Fat Boy was a huge pain. I had to get special parts milled to make it happen. I said no three times, and the guy kept asking why. He drilled down to the reasons and then we addressed those.
The whole point about the lead acid battery is it does not burn.
Yeah it does.
Did you ever get that acid splashed on you?
I had a pair of jeans dissolve when I got splashed.
SLA is a bit more contained and AGM has the weave to help keep the acid from splashing.
The power to rate ratio sucks though.
Hydrogen gas given off during charging (or is it discharging?) is VERY explosive.
People have gone blind from getting battery acid splashed in their eyes.
I had a freind that was splashed with battery acid from a car crash.
Either way, impact is not good for ANY type of battery.
Nice-looking bike! Interesting rims. Why the cutouts, and what's the orange stuff peeking through? Some kind of puncture-proofing foam or just a colorful rim liner?
Yeah it does.
Of course to all points!
Still the lead acid battery itself does not create the type of fire you get from Li-Ion. You say you want a simple e-bike, with a rheostat. I was there. Now, you are changing your mind and want Li-ion.
Yeah, but if they had Li-Ion batteries back in 1931, I'm sure the box would be filled with Li-Ion cells.
I can't read that language, but it looks like it goes 70 km on a charge.
Can you imagine how far it would go with a box full of Li-Ion?
I might change my mind on the rheostat too and go with a simple controller.
Rheostats aren't very efficient.
But no artificial intelligence trying to analyze me.
Jeremy, the rim cutouts are a solution towards lightening up a fat bike rim. Both my Specialized FatBoy-90mm wide rims and Haibike Full FatSix-80mm wide rims, have them. In the early years of fatbiking, lots of fatbike owners got creative in the types and colors used in their own rim tape. The white rim tape on the FatBoy is what came on it from Specialized.
With that many holes in the rim, you can imagine the need of an owner going tubeless has to ensure those rims are sealed airtight!
