Merle Nelson
- USA
That sounds like incredible battery range. Probably mostly because you are putting in so much effort. Glad to hear it.
@Deacon Blues - what you describe is a feature of the Motor Torque (?) setting; the bottom row programming parameter…..It finally stopped raining, so I took advantage of the decent weather to go for a 70km ride (40miles).
Because the chain still skips in the smallest 11t cassette cog I didn't go lower than the 13t cog, which topped out my maximum cruising speed at around 20-21 mph at my preferred cadence (around 80).
I'm hoping that the 48t front chain ring I ordered will allow me to cruise at a bit higher speeds, maybe in the 22 to 25 mph range. I don't often ride at those speeds, but there are times when I want to haul ass.
The bike performed well and felt really comfortable.
Because I knew I was going 40 miles I took along my extra battery.....just in case. I don't know what that battery weighs, but I can tell you that damn thing is HEAVY!
I ended up not needing it. I started out with 92% and ended up with 30%. Half the ride was in level 1, but I found the bike to be too heavy for this level, when trying to maintain a decent cruising speed.
For the last half of the ride I bumped the power up to level 2, which felt a lot better.
At one point it felt like the power had fallen off and I had to pedal harder to maintain the same speed. Shortly after that the full power came back on. I'm not quite sure what was going on here and I'll have to see if that happens again on future rides.
No.Did you ever do anything with your derailleur?
TBH, about what I'd expect for an Ultra with Archon controller. I get similar range (with some hilly terrain) on a FS bike with 840wh battery averaging PAS 2. I generally don't charge above 80% just to keep battery healthy but never have range anxiety, granted my rides are typically less than 30 miles.That sounds like incredible battery range. Probably mostly because you are putting in so much effort. Glad to hear it.
For the record, I was only partially correct. The EX1 also has a spacer built into the end of the cassette:If I remember correctly, the EX1 cassette requires a 1.85mm spacer on the freehub which would imply the biggest cog is spaced outward somewhere around where my 2nd cog is. That alone.....
To reduce cross-chaining, the position of the biggest cog is 7mm inwards compared with an 11-speed drivetrain, Braedt said.
I'm sorry to hear you're still having issues, I think there must be something else going on. It just shouldn't be this hard--it makes me feel guilty being able to cruise at 30+ MPH (pushing fat, knobby tires) without a hint of skip on 11 and even 10 tooth cogs. I know nobody wants to spend money on a brand new bike, but I couldn't handle a bike that couldn't use all its gears. I have to wonder if starting over with a completely new Sram or maybe higher level Shimano drivetrain would fix things.Even though I've solved most of my chain skipping problem I would still not recommend anyone ordering my bike (with the older frame, which has the much wider rear axle) with a derailleur setup.
Glad you published.Even though I've solved most of my chain skipping problem I would still not recommend anyone ordering my bike (with the older frame, which has the much wider rear axle) with a derailleur setup.
With the fat spider, which gives the bike a huge 'Q' factor, there is still some skipping, and I suspect I'll be frequently going through chains and cassettes.
If I had it to do over again I would have gone with the Kindernay, or Rohloff hub. I know they have their own set of negatives, but (in my humble opinion) they're a much better option that the derailleur setup.
Hopefully, Pushkar has solved this huge cross chain problem with the new UC Pro frames that are coming.
I'll be interested in how the derailleur setup works on your upcoming bike.
Your 197mm rear is set for snow tires.How committed am I to this bike? I wanted to download the X1 software to modify the bike's controller, per Pushkar's video, but all my computer stuff is MAC, which won't work with the X1 controller software, so I bought, during Black Friday week, a Windows laptop from Costco.
I applied for the needed password and now I'm waiting for it so I can do the changes.
Using a Windows machine is a real learning curve for this (OLD) MAC guy.
On the riding front, I was planning on going for a ride today, but the temperature dropped below freezing last night and at 10:00am and the roads were still icy,
I did plan on a 50km ride, but that will have to wait until it warms up a bit. Luckily, I've got all the cold weather gear, which includes a balaclava, heated gloves and heated socks. The joys of living in the Great White North. Actually, where I live the weather is quite mild (for Canada). We seldom get snow, and I can usually ride year-round......when it isn't raining.
Unfortunately, the forecast is for snow tomorrow, which is kinda funny, since tomorrow is when I'm taking my new Ford Maverick in for snow tires.
The christini spider, purpose designed for xx fatties is my choice and I check daily for availability. Next week, I hear.For the record, I was only partially correct. The EX1 also has a spacer built into the end of the cassette:
From here: https://www.bikeradar.com/news/sram...5&type=gallery&gallery=1&embedded_slideshow=1
That's a pretty significant difference, putting it on par (or even a bit better) than the Prime 9 system for having a good chainline in all gears. It should make chain-rub a non-issue for even the fattest tires when properly set up so it has a lot going for it particularly for fat bikes.
That's not the case. There is no difference in cassette location between 190 (quick release skewer) hubs and 197 (generally through axle hubs). Many hubs can be converted from one configuration to the other--the cassette doesn't move.While the bafang fat-bike spider fits 190mm offsets on it's outer side, the christini's inside mount is for 190mm and the outside is 7mm further out. Being two gears thinner, spacers make sense.
Yes, Q Factor is a personal thing. I have bad knees and the wide Q of Fatbikes don't bother me at all. When I switch from a mountain bike to a fat bike, I notice the Q difference for a few seconds, then forget about it. Some will find it does bother them. I don't think there's any way for individuals to know if it'll bother them without giving it a try.I do a lot of riding on my carbon road bike, which has a fairly narrow 'Q' factor.
I'm thinkingThat's not the case. There is no difference in cassette location between 190 (quick release skewer) hubs and 197 (generally through axle hubs). Many hubs can be converted from one configuration to the other--the cassette doesn't move.
Good news for the knees. I'm happy with a 25mph cruise. 48t will provide that easily.I do a lot of riding on my carbon road bike, which has a fairly narrow 'Q' factor. When I hopped on the WW, with the fat spider and extended cranks, I could tell, right away, that my feet were (a lot) farther apart.
I was initially concerned that this much wider stance would have an impact on my old knees, but that hasn't been the case. After a non-stop 70km ride my knees were fine.
For my bike, with the 197mm rear axle width, I think a hub shifter is a better way to go. Having said that, I'll have to wait for my final evaluation, after I install the 48t I've ordered.
When it comes to derailleurs, chain rings, and group set components I'm a serious noob. This is all new to me, but I enjoy the challenge.
My WW bike's mission is 'high speed' cruising. When I say 'high speed' I don't mean 30+mph. I'm very happy with 25mph, max, and only on long straight stretches of road. Other than that, I don't mind going slower and enjoying the ride and the scenery.
Fn'F, do you know when you're getting your bike?
I don't know the details of that frame, but people quite commonly use 190/197 interchangeably and/or incorrectly. In most contexts it doesn't matter because it denotes the same size frame, tire clearance, chainline, etc. Jump down to 170/177 (the older, smaller "fatbike standard") and you are talking a different sized frame, likely tire clearance, required chainline, etc. That's why in charts like this they are lumped together:Deacon has 197mm skewers. I ordered 190mm axles. I've been under the impression the cassette did move further outboard with wider widths -
why bafang made a wide offset type spider, as well as to eliminate rubbing.
I'm a go out on a limb here -- from my experience the offset of the ring gear has nothing to do with a Q factor -unless the ring is too close to your pants - not John Wayne, more that Slim Pickins limp.
Hopefully when people dig into the programming of the X1 they'll figure out how to improve that. With my stock Bafang I have it down to less than 1/4 turn. Of course that's still a lot if you're in a really wrong gear, but in an appropriate gear it works pretty well.With my UC Pro I'm hampered by trying to start off on a really heavy bike and with a motor that needs at least 1/2 revolutions on the pedal/crank arm to start applying power.
