OK.. so I poured over my research and this is a good time as any to start discussion on a custom display for the Watt Wagons bikes
Here is what I have gathered so far (converted to tablular format)
Display features
1. Nicer display (colors, contrast)
2. Larger display - 3 or 4 inch
3. Some form of power output for phone charging
4. Turn by turn navigation when paired with a phone
5. Display of other analytics from the motor / controller
6. Easier way to switch between ride profiles
7. Reach goals - ability to pair with controller - disables the motor if removed from the bike.
8. Reach goals - electronic shifting display (if we are ever able to do it)
Added
9. Visible through polarized glasses
| Feature | Importance (High /Med / Low) | Available today (in our prototype) |
| 1 | Nicer Display (Colors / Contrast) | High | Yes |
| 2 | Larger Display (3+inch) | High | Yes |
| 3 | Power output for phone | High | Yes |
| 4 | Navigation when paired with phone | Med | Yes - with app |
| 5 | Motor Analytics / status | Low | No |
| 6 | Switch between ride profiles | Low | Yes |
| 7 | Reach goal - motor disabled if removed | Med | No |
| 8 | Reach goals - electronic shifting display (if we are ever able to do it) | Low | No |
| 9 | Visible through polarized lenses | Med | Not sure. Need to test |
| 10 | | | |
Technical requirements
A. Low power Bluetooth support
B. UART (current Ultra systems) and CAN (future Ultra system) compatible
I will collate your feedback and see what works.
thoughts?
Edit: Added point #9 for display features, plus current known capabilities.
