pushkar
OK.. so I poured over my research and this is a good time as any to start discussion on a custom display for the Watt Wagons bikes
Here is what I have gathered so far (converted to tablular format)
Display features
1. Nicer display (colors, contrast)
2. Larger display - 3 or 4 inch
3. Some form of power output for phone charging
4. Turn by turn navigation when paired with a phone
5. Display of other analytics from the motor / controller
6. Easier way to switch between ride profiles
7. Reach goals - ability to pair with controller - disables the motor if removed from the bike.
8. Reach goals - electronic shifting display (if we are ever able to do it)
Added
9. Visible through polarized glasses
Technical requirements
A. Low power Bluetooth support
B. UART (current Ultra systems) and CAN (future Ultra system) compatible
I will collate your feedback and see what works.
thoughts?
Edit: Added point #9 for display features, plus current known capabilities.
Added
| Feature | Importance (High /Med / Low) | Available today (in our prototype) | |
| 1 | Nicer Display (Colors / Contrast) | High | Yes |
| 2 | Larger Display (3+inch) | High | Yes |
| 3 | Power output for phone | High | Yes |
| 4 | Navigation when paired with phone | Med | Yes - with app |
| 5 | Motor Analytics / status | Low | No |
| 6 | Switch between ride profiles | Low | Yes |
| 7 | Reach goal - motor disabled if removed | Med | No |
| 8 | Reach goals - electronic shifting display (if we are ever able to do it) | Low | No |
| 9 | Visible through polarized lenses | Med | Not sure. Need to test |
| 10 |
thoughts?
