JonVonGod
Picked mine up today after 2 weeks in the shop. They rebuilt the hub and all is quiet for now!Got mine today as well. Same solution, all new internals on the original hub. There was a failure of the clutch plate mechanism after I heard the scratchy noise and turned the bike in. during the testing of the replacement motor (which turned out not to be needed). I just got back from a ride and it sounds and runs perfectly. @GuroUno I hope you like the AXS as much as I do. If the controller clamp ring is already right next to the grip, I don't know how you get it any closer. I actually wanted it further away so I don't keep accidentally shift when I go over bumps. See the photo of my cockpit in the above post.
UPDATE on 6/14/20: THE SCRAPING NOISE IS BACK! Time to upgrade to the Onyx hub?
