D
		Deleted member 18083
Guest
Chris, I think the answer is ‘Yes’, providing you load the bikes nose-to-tail. The handlebars are high so it is likely that there won’t be conflict between handlebar and saddle - another good reason for a dropper post.Do you know if the rack is capable of taking two Homages? That would be around 60kg right?
The two bikes will be approximately 60 kg. Also consider the tow ball capacity (2 bikes + rack).
David
