Relocate LCD position
RHelton10
Just curious if I’m on the only one...
I’m looking at different ways to move the LCD from the factory location to where it will sit approx 3-4” in front of the headset so it’s not in the way of a headtube cellphone mount. Anyone else successfully figured out how to do this, and if so, what parts did you use / fabricate to relocate it?
For what it’s worth, I have a RadCity model, but it looks like it’d be the same process on any of Rad Power’s bikes.
I have a 2016 Radrover, and the LCD is mounted with 2 hex screws. I don't know if they have made any changes to the mount in the newer Rad bikes.
I did something like that. What I did was took off the LCD and rotated the brackets ~180 degrees. Then took a small acrylic sheet and drilled 4 holes: 2 holes to mount the sheet to the upside down brackets (+ 2 bolts & nuts). And 2 holes further forward to mount the LCD using the 2 original hex screws.
Have you checked out the thread about handlebar bar extender for 18 Rads: https://electricbikereview.com/forums/threads/rad-rover-handlebar-extender.25708/
You could either move the LCD screen or the phone mount to the extender. Most of the extenders are under $20 on Amazon, take about 5-10 minutes to install, and they look really nice.
Pic of RadCity Step-Thru with Odier extender for Vibrelli mount for iPhone 6S Plus with Mophie battery case and Niterider 1800 Pro light.
Thanks - glad to see I'm not the only one.
Ok just read through that post and I think that's a perfect solution - thank you!!! I didn't realize they made those.
