Fast n' Furious
- USA
- City
- San Diego
Don't want to be knowingly rude. I'll post the answer on Gumbo's site.
None of my Thuds have ever squeaked. Since I posted in here last I put that Thud on the second bike, where the first one has the Kinekt on it. Easy now to make truly direct comparisons given identical frames etc and only different seatposts.Body Float/Knekt over TB for sure. I have had both. I am a larger rider and the float has better performance and you don't have the squeaky noise you get from the TB's elastomer insert.
I have heard other TB squeaking on other bikes as well. Which one do you prefer? Why did you buy the TB after first owning a float, or if I got the order wrong why did you switch up? I have never experienced the pogo effect with Body Float I weigh 225.None of my Thuds have ever squeaked. Since I posted in here last I put that Thud on the second bike, where the first one has the Kinekt on it. Easy now to make truly direct comparisons given identical frames etc and only different seatposts.
I was on the phone with Kinekt today. I am buying a 90mm suspension stem for my new bike. Those stems just play too big a role in wrist and hand fatigue elimination to do without. I confirmed with them I can use the orange-striped upper seat spring as an extra-extra-firm spring over and above the three they include in the stem, and ordered one. Also ordered the extra firm dampener kit. I have those on my other three Kinekt stems so I know its what I need to make the stem work for me as advertised.
- The Kinekt XL2 provides smoother ride and better isolation.
- The Thud LT with the max firm elastomer rounds off the sharp edges on impacts. It does not advertise to be an isolation post like the Kinekt does and the two are genuinely different in what they do. the Thud essentially does the job of easing the impact on your spine for a lot less money; although it is still pricey as it is.
- The Kinekt XL2 has a pogo effect at high cadence rpms. It cannot be gotten rid of by adjusting preload. I can reduce the effect but taking it to the point where the effect is gone makes the unit bottom out with increasing frequency. I weight 250 lbs and the Kinekt XL2's weight range is if I remember right 250-340 lbs. I looked it up in the previous posts so whatever I said then is correct for sure.
- The Thud has zero pogo no matter what.
- Spine and bum are just as comfortable on either after equally long rides.
What Thudbuster post are you referring to? There is a big difference between the LT and ST versions. I have both and the LT does not squeak. The ST can begin making noise after prolonged use but it's easily cured by applying a drop of mineral oil to the bushings.Body Float/Knekt over TB for sure. I have had both. I am a larger rider and the float has better performance and you don't have the squeaky noise you get from the TB's elastomer insert.
Thudbuster LT. I have also owned the ST and there's no point in limiting it to the lesser performance unless you have, perhaps, aesthetic issues to consider. Recently this changed though because now the current ST model has a 330 lb weight limit, over and above the hard 250 lb limit of the LT.Which one do you prefer? Why did you buy the TB after first owning a float, or if I got the order wrong why did you switch up? I have never experienced the pogo effect with Body Float I weigh 225.
