Catalyzt
 - USA
As many of you know, I ride an XCish 46ish pound Class 1 FS eMTB with a 250 watt 40 nm motor and 34mm Suntour middle-of-the-road front fork.
I break 30 MPH fairly frequently and occasionally break 40 MPH, but do that only very briefly on pavement that is smooth. On the trail I'm usually on novice trails with intermediate segments, and occasionally on intermediate single track with a few very short advanced segments. Generally, I ride 75% terrible pavement, gravel, broken glass, and junk, and 25% dirt. Hills where I live are steep.
This bike used to weigh about 49 pounds. I dropped it to 46 by going to Maxxis Ikons 2.2s (I was coming from Riddler 2.3s) and going tubeless and getting a CF seat. And-- for many reasons, not only weight, also decreased rolling resistance-- it made a HUGE difference. I was able to get to another range of hills and ride much more interesting terrain. It's easier to carry down stairs or over gates or obstacles, and safer-- less risk of losing my balance and falling, etc.
My first decision was, whether to upgrade and retrofit my other bike -- a 42 lb. hardtail w/ a TSDZ2B that has a cracked motor housing. I believe, with a variety of mods, this could be a 40 lb. 80nm+ class three monster, and I really want to do that project, BUT, if I'm going to spend $2,000 to $2,500, I think the money may be better spent on the FS than the hard tail.
That is not the question I'm asking at the moment, but I'm open to thoughts on that. My decision is not finalized. The main reason I'm more likely to invest in the FS bike is because it is so underpowered, and for that reason, everything is likely to last longer, from the motor itself to the chain, the crank, the gears, the battery, etc. That makes investing in the FS bike a better investment, I think, particularly if the economy goes to hell and I have to retire before I really want to. I'm 67.
What I'm trying to figure out is how much weight I can lose on the FS bike and where to lose it. There is, as @PedalUma noted, a point of diminishing return. However: There is a long, mild upgrade on the way to my favorite trail that I could probably do with less assistance if I could shave a little more weight, and that could mean more riding on the best terrain w/ less range anxiety.
But I'm not sure I'm getting great advice from my LBS on this. They say things like, "you need a 36mm Fox Float Fork if you replace the fork, the 34mm Fox Float is not as robust as your Suntour and not for an eBike." This doesn't make sense to me. My bike is very, very underpowered, and it's already pretty light and I only weigh 155 pounds, so what about my bike being electric makes it less suitable for the 34mm? I don't do big drops, nothing bigger than riding of a medium-height curb. I'm on blood thinners, have no reason to take that risk.
They also say things like new wheels would cost me $2,000 and would only save me a pound, or that it's pointless to replace the pedals, and that it won't save significant weight. I think they're not thinking it through-- that's rotational weight, and actually, I could lose half a pound by going with CF pedals. (It is true that I could, potentially, crack one, but that's unlikely to cause an accident or keep me from getting home. I think.)
Anyway, what do we think would be my priorities for saving weight and staying within my budget? Here are the items I'm considering:
Wheels - 1 to 2 lbs (I think my current wheels are heavy for what they are, my LBS says it's impossible to figure out wheel weights. My hunch is, I could shave a half pound or a pound just going with better allloy rims, maybe 2 lbs if I went CF. Pedal has some ideas about lightweight, low-resistance CF wheels and hubs I need to follow up on.)
Tires - .5 lbs (options here are VERY limited, because my tires are light already. I'd be going with 2.0 inch Schwalbe rocket whatever. That's as thin as I probably want to go for intermediate trails-- and could be a mistake. Maybe the Maxxis Ikon 2.1s are already in the sweet spot. If I can replace them, they are down to 15%.)
Pedals - .5 lbs
Bars - .25 to .5 lbs.
Fork - 1 to 2 lbs. LBS is claiming 1 lbs, but I think he's looking at the 36 and ruling out the 34 unreasonably.
Seat post - .25 to .5 lbs
Obviously, what's most expensive would be the fork -- probably just over a grand -- and the wheels. And obviously best to use rotational weight first, and weight low on the bike second, weight high on the bike makes a lot less difference.
Thanks, I can supply more detailed info about my current fork, etc. Pedal, I know I gotta call a guy about a horse-- or a wheel-- but there are other items on the list as well.
Pedals - .5 lbs
