This most likely will be a necessity if you have ordered the Rockstar. Not sure which size you would need. https://christinibicycles.com/buy/buy-parts/
A Freewheel?! Stupid, stupid, STUPID. Why? Because a freewheel means a freewheel hub, which with any hard riding mean a bent and eventually broken axle. Elite Class my a**. That is Walmart there. Oh, and I like how the artwork depicts a big 50T cassette and high-end derailleur, instead of the puny 28T freewheel and low-end derailleur.
EDIT: oh, and a twist shifter as well.No performance mountain bike has twist shifters. Not in 30 years, anyway.
Exactly online addy,, Same biz plan that made oh you know AMZ the largest e-tailer in the world.No, he said, "I believe Sondors biz plan is narrow to near zero margins to expand market share." That is to benefit Sondors, not the market.
I guess that disinformation makes buyers more at ease. But where are the facts? If anyone believes ANY eBike builder does it to the benefit of the market rather than themselves...well...I have a good deal on a bridge!
I know EXACTLY what you mean! Oh I was SO close to doing the step through, especially at $500 less!! I'm not that heavy into off-roading, so it would have worked but in MN I do want to ride in the snow. That look also just got me over the edge for the Rockstar! Both LX and RS are beautiful! There was just something about that yellow that grabbed me!!At 1999 I think the LX is a better value. Fatty hardtail step thru with Hydros, Ultra motor, and a 21ah battery integrated. 104 bcd adapter on order for me.
SONDORS Elite Rockstar - Detailed Specs List
Part Details
BATTERY SONDORS 48V, 21AH, Genuine LG cells
MOTOR Tuned for SONDORS - M620, 48V, 750W mid motor w/ controller
CHARGER 48V, 3A Smart Charger
DISPLAY SONDORS by Bafang C240 LCD
GEAR SENSOR 5V, 500MM, CAN communication
FRAME Bespoke Aluminum
FORK Tuned for SONDORS - Suntour XCR 32 LO R Air Boost. 120mm travel (internally adjustable to 140mm max) with rebound and compression adjustment and lockout. 15x110 thru axle.
Magnesium lower with forged crown and chrome steel stanchions. 2300 grams
REAR SUSPENSION Tuned for SONDORS @ 150mm rear travel - DNM AO-38RC, 0.28 KG (0.62 Ib), 190 mm (7.83 inch), Adjustments - Rebound / Lock out / Air Pressure Adjustable,
Dark hard-anodized AL-7075 Ø 10 mm (0.39 inch) shaft. Dark hard-anodized AL-6061 shock body. Applicable Riding style, XC / TRAIL
REAR DERAILLEUR
Shimano RD-M310,ALTUS 7speed, AMFTZ5007428 MULTIPLE FREEWHEEL SPROCKET, MF-TZ500-7,7-SPEED, 14-16-18-20-22-24-28T with Twist shifter
SHIFTERS
FREE WHEEL
FRONT BRAKE Tektro Auriga E-SUB(HD-E520), black, hydraulic disc brake, cable length:850mm, 180mm Rotor
REAR BRAKE Tektro Auriga E-SUB(HD-E520), black, hydraulic disc brake, cable length:1650mm, 180mm Rotor
PEDALS Wellgo B087 9/16 CR-MO , aluminum ,black BS
FRONT RIM DP-45*27.5*13G*36H,A/V,ALLOY
REAR RIM DP-45*27.5*13G*36H,A/V,ALLOY
OUTER TIRE Maxxis tire 27.5*3.0
INNER TIRE 27.5*3.0
SPOKES 13G*270mm,14MM,BLACK
SPOKES 13G*268mm,14MM,BLACK
HANDLEBAR Promax HB-3188-W700,6°,Rise:30
STEM Promax MA-410,alloy
GRIP Velo VLG1670D3
HEADSET SONDORS H383 AEM,ALLOY
SEATPOST KS Dropper Post
SEATPOST CLAMP 319 QA
SADDLE Gel saddle
CHAIN KMC #Z7,EPT,1/2*3/32*126L
FRONT HUB D041SB-B155,36H*13G,ALLOY
REAR HUB D982SB-HL-B12,36H*13G,ALLOY
THROTTLE FT-130X,700MM
reflector for wheel 722SS C
reflector 122C,Front
reflector 122R,Rear
9 months of Sondors upgrade parts sales and support. It's not an accusation, rather a statement of fact. But Sondors has it's own cult of believers. And for some it all works, while others discover that being their own repair and warranty service isn't all it's cracked up to be. But it's not just Sondors. It's the entire business model.Do you have any hard proof to support that accusation? (other than anecdotal)
Its too bad they are only offering the huge fat tires in those three models. I just chatted with rep on their site asking about a 2-3 tire version for us commuters, paved street etc. but he said not an option on those new models.
There are several different tires that can be used for street use. Part of the equation will be how wide the rims are on each model. I thought that the LX was the only one with fat tires. The rockstar had off road tires and 3.0"? There would be lots of street options for the rockstar and the cruiser. finding a narrower street tire for the LX will be the challenge. There is not a great selection that will fit.Tires are available. I looked at Vee fatties for street use
It has been reported Sondors has upgraded their CS, the parts, and warranty department. I cannot verify this personally as i do not own a Sondors. I hope they have. With the e-bike market growing CS or the perception of CS will be an ever important part of business.9 months of Sondors upgrade parts sales and support. It's not an accusation, rather a statement of fact. But Sondors has it's own cult of believers. And for some it all works, while others discover that being their own repair and warranty service isn't all it's cracked up to be. But it's not just Sondors. It's the entire business model.
