You can swap between 9 and 12 ah on any Neo 36V bikes.
I have a 9ah Jumper and a 12ah Race. I have often swapped their batteries.
Nope
Need to update that last post, 12 amp doesn't seem to matter, I have been riding trails on throttle and kicking the motor on when needed, 30 mile run down the Santa Ana River Bike Trail only cost me 1 bar. back to running with my 9amp. I ride 4 miles each way to work every day, come home with 2 bars gone, do a quick 1 hour charge back to full bars every night. not too sure if thats bad for battery life or not.
How can there be such discrepancy in distances achieved when the weight of the participants is within, say, 20 lbs of each other, and the terrain ridden seems to be somewhat similar in that there are a mixture of some hills and some flat areas. Some people report they lose 1 bar for every 4 miles ridden. Someone else reports they lost 1 bar for every 12 miles ridden (same size battery), and both people are reporting they used a similar level of assist on the bike?
The bike I'm purchasing (the Evo Street, 350w bike, which weighs 57 lbs, and is an urban cruiser) claims a possible distance up to 60 miles. Obviously that would be on the lowest level of assist with active pedaling and probably on fairly flattish terrain and starting with a fully charged battery. But if I were only getting 20 miles on the lowest level of assist, with active pedaling, and fairly flattish terrain, with a charged battery, I'd feel like I'd been lied to.
Think of it like this: a 36V 12ah LiIon battery is 30 bigger than the 36V 9ah and you may also be looking at different amounts of power density based on the type/quality of cells used inside the battery. The manufacturers base range on totally flat ground and generally with a person weighing about 170-180lbs. Any incline requires more energy and we see underinflated tires as a regular problem contributing to low range issues. The tire width and composition along with pressure will measure into rolling resistance that affects range. Its not common; however, you could have a battery with a weak cell group which would lower range, but your LBS would need to confirm this.A good question.
On my jumper (2013 version maybe?) I can get around 10 miles using the 9Ah and around 12 miles using the 12 Ah.
But this is on single track with elevation change of around 1200 ft, averaging around 12-14 mph, with a rider weight of about 200 lbs. (@ 18 km dist, 350m elevation change, 19 km/h, 91 kg).
This is in eco mode.
I'd be happy with less boost and more distance, but there does not seem to be any way to accomplish this.
But it is fun. Good luck.
Mike
Colorado, USA
