How many levels of assist do you have? my Giant with the Yamaha Syncdrive Pro with 500WH battery has 5 levels and with a full battery it shows the following range!I assumed I'd get around 50mi. based on what my display shows at 100% charge on high assist. I'm thinking I should now cut that range in half to be safe
LOLIn the sense of being able to predict how much range I have I do not find them to be very "accurate" (in the technical sense) at all. However, I find the range estimates more useful than the battery meter or a battery percentage in estimating how far I am likely to be able to travel on a charge.
As many have noted, when the battery level is very low any and all estimates or even the battery voltage isn't necessarily a good predictor of how far you can go.
I ride a lot in quite varied terrain, and also often on less-than-optimal surfaces as well, both of which make it very hard to estimate range. Though in general, an "accurate" range estimator would need to be able to predict the future to be "accurate", and if I had a gadget that could predict the future I would use it in the stock market and not on my e-bike.
I'm not looking for acute accuracy. Ballpark is good enough. Sounds like my Yamaha pw might be off by more than 50% on a regular basis
My experience is the same as Richard's; and, until Coffee gets his 'gadget' to market, I'll use the one under my helmet to factor in terrain and wind to adjust distance remaining as, I suspect, we all do.All three of our Bosch-powered bikes seem to be quite accurate in their range projections.
Apart from an accurate display, it also had quality Ergon grips and a nice bell. At the moment, I cannot think of any other complimentary thing to say about it.How did you like the Kalkhoff?
