Hi i have a samebike LO26 v2 (750w motor) with M6t lcd display
NightKin
United Kingdom
i have unlocked the max speed via M6T lcd but cannot change any PAS settings as they locked can anyone help?
Update have decided to purchase a new lcd display ,E-bike SW900 LCD Color Display Speed Control Panel 6 pin to see if it unlocks the settings it has the same pinout as M6T
If successful will update you all in about 3/4wks
  • LCD-M6T.pdf
Mixing displays and controllers from different manufacturers rarely works. WHile the pinouts are usually the same, the communications protocol are different. They won't work. You might get the controller powering up with a working throttle and pedal assist, but the display cannot change it or show speed.
