J3ON
- Canada
Hey J3ON
The 3 HD 750 BIKES i've messed with had 80-90lbs of air pressure in the front shock out of the box. (port is on the underside facing the ground) Get a decent Front suspension pump with gauge and boost that to about 90-110psi. It could damage the suspension to exceed 120psi be careful- I'm 250lb and ride somewhat aggressive. I like it 105-110psi. Also on the bottom side of the other fork you can adjust the red rebound knob. My fork has 12 click settings for rebound. I set mine to 3 clicks in out of 12. Mess with it until it suits your body and riding style. Get this dialed in and you'll be pretty satisfied with the RST front end. Hope that helps.
↓ ↓ I have this pump, it works good.↓ ↓
GIYO High Pressure Shock Pump, (300 PSI Max) for Fork & Rear Suspension, Lever Lock on Nozzle No Air Loss
Hi Wendigo,
Until now I had no choice but to ride with the fork completely locked, I'm an heavy weight too and when I'm on the bike the fork gets completely compressed but now I will try some adjustments by turning the red cap as you suggested.
This is exactly the kind of advice I was looking for, but 110lbs !?
I'm 265lbs and I thought 80lbs was the maximum, from 80 to 110 there is 30lbs of difference, what is your fork model ?
