Very Nice Bikes : Unfortunately Not Meant for Taller People : 19 inch Frame for Men is pretty small 17 for women : Court at 5'9 Looked Big on themBikes look really nice.
Since they enclosed the motor with metal, to closely fit around it, they likely had no other choice but to run the wiring that comes out of the BBs02, externally, and keep it relatively serviceable for when or if there are electrical issues, controller, etc. The motor is designed to replace an existing bottom bracket assembly (for typical aftermarket sales in DIY ebike kits) , so they just built around that. There would have been no easy path to go back through the seat tube intersecting the bottom bracket, due to the natural exit of wiring from that BBs02 motor. The other place wiring is exposed related to the battery is for the second add on battery. It's at the bottom of the second battery and fairly short. Looks thick and robust.@DÖST, beautiful design and maybe someone else already asked, but what's with the exposed wiring between the battery and motor on the underside? Seems awfully vulnerable to me...
Hey CityExplorer, Dave from DŌST here, the rear rack is rated for 100 lbs... sorry about the confusion, I'll follow up to find the 60 lb rating and remove it, thanks for your helpWebsite has 2 different numbers on it, 60 & 100.
Hey Browneye, Dave from DŌST here. The bikes will ship May/June - we've been delayed due to the coronavirus affecting manufacturing in Taiwan. We'll post any updates on shipping on our website, cheers, DaveYou naysayers look petty and silly on a vendor thread. Start your own thread or post over here: https://electricbikereview.com/forums/threads/whos-looking-at-new-startup-dost.32271/#post-252132
When are these bikes slated to ship on pre-orders?
That was Webcurl's question, but he'll be happy to hear it is 100lbs I'm sure. I was pretty sure that 100lbs was correct given the design is part of the frame.Hey CityExplorer, Dave from DŌST here, the rear rack is rated for 100 lbs... sorry about the confusion, I'll follow up to find the 60 lb rating and remove it, thanks for your help
TY for the ride-report!Some comments on my short ride on the Dost ebike:
The Good
-this is a good looking bike, with a very good fit and finish.
-the bike feels very stable. Very easy to ride and quite agile.
-this bike has tons of power. The speed limiter was not in place and pedaling hard I was able to hit 48kph on a flat section.
In the top (5) power range I had no problem cruising along at 40kph, with just normal pedaling. If I bought this bike I'd also buy the extra battery, because it's so easy to ride this bike at faster speeds.
The Not So Good.
-each and every time I stopped pedaling I could hear and actually feel a clunk coming from the motor. I'd be interested to know if this was normal for Bafang mid-drives or if it was a single issue with this bike. This is the first ebike I've ridden with a Bafang mid-drive.
-Dost has to do something with that wiring harness that runs underneath the motor. It looks like crap. How hard would it be to come up with a plastic cover that bolts on to the motor case?
Overall, my wife and I both like this bike and it's on her short list.
Hi Scout592, They did not have it in stock but they have a shipment coming in around May they said.But do they have any in stock yet?
No.each and every time I stopped pedaling I could hear and actually feel a clunk coming from the motor. I'd be interested to know if this was normal for Bafang mid-drives
Hi Keith, sorry for the late reply... great question, the plan is to have additional water bottle mounts on the seat tube so you can have both the extra battery and a water bottle attached at the same time, or two warer bottles if no extra battery. This mount would work for a folding lock (i.e. ABUS) carrier as well. Cheers, DaveA question for Dave from Dost. I am interested in ordering second battery when I order bike but not keen on giving up the water bottle holder location. Have you considered a bottle holder that can click into where the 2nd battery mounting hardware. In that way most of the time I would just use that spot for water bottle but in off chance I want to go with second battery I would only need to snap out bottle cage mount off battery mount and snap in battery. Thoughts or is this already in the works in future version?
Keith
Hi Deacon, glad to hear that overall you enjoyed riding the Drop and you got to meet Sam at the office. The clunk is not normal, I'm not sure what might cause that. I've got a ton of miles on several Bafang mid-drives (I commute 365 days a year) and this is new to me. I will say that because of the cadence-sensing design, when the bike is in PAS 5 (max torque, max current) the motor does produce sound as it goes from off (zero torque) to on (max. torque). Also, thanks for you continued participation here at EBR, all these comments serve to help us improve our designs year on year. DaveSome comments on my short ride on the Dost ebike:
The Good
-it has tons of power. The speed limiter was not in place and pedaling hard I was able to hit 48kph on a flat section.
The Not So Good.
Hi Scout, Bardown is correct, both the Kope and Drop models are due to arrive end of May beginning of June. We've just had confimation from our factory that they will meet this delivery date. Thanks, DaveBut do they have any in stock yet?
