How much would it cost to have it clear coated?yes.
can't change colors on that one.I found this newer version of the color configurator.
https://cdn.soft8soft.com/AROAJSY2G.../applications/wattwagonsbike_v_0_5/index.html
I can't see where @pushkar has added more color choices.I found this newer version of the color configurator.
Yes, cerakote has this1. Can a clear coat be added to give the coating a more glossy look (I'm not a fan of matt finishes).
				 www.cerakote.com
					www.cerakote.com
	Working on that logic. The code is set up in a weird way right now.Question @pushkar , now the second color is only the middle inside band, and the third is the inside edges.
If you only want two colors but applied to all the inside (middle and edge) like before, do you have to order three colors with two of the same?
good point. That makes it a lot simpler.If you can have the whole middle paying for just a second color, then you need two options in the secondary choice, Center or Center+edges
Yes will add the descriptions and additional colors.For those who ordered swatches, the configurator's "Classic Red" is Cerakote's "Ruby Red" and "Lipstick Red" is "Firehouse Red". Ruby Red is a dark red, and Firehouse Red is also dark, almost a brick red. The brightest red on Cerakote's site is Stoplight Red (C-143) and does not appear to be available in the configurator. Any chance that can be added, Pushkar? That would make for one hot-looking bike.
