Change Display on FLX Roadster (G3)
rcdanner
I like my new Roadster. But the display is not very visible in the bright Arizona sunlight. I can barely read the trip miles. Speed is a little better since the numerals are quite large. I’ve adjusted the angle of view to the best position. But I’d like to get a better display. Can a new Bafang display for mid-drive motor be used to replace the subpar DPC240? Will other Bafang displays such as HMI-850C work and be plug compatible? Is there any programming to do?
The DPC18 on the Blade is outstanding. Not sure if you can just swap out. Might wanna give flx a call.
