older e-City over current motor cutout (Error 33)
Hutchwilco
Hi,
Appreciate finding a smartmotion-specific forum to post.
I wonder, having found the motor controller used in my Smartmotion ecity is made by Ananda, whether there is a forum for that range of controllers?
My issue has been Error 33 presenting and the motor cutting out if I use the throttle grip, or high PAS (pedal assist) modes.
The manual and this guide outline this Error 33 means over current, and to check connection between the controller and the motor.
I've done that and all look ok, well mated and no evidence of heating.
I have found that the battery receptacle/receiver has a damaged/loose pin, which is never good for high currents, but that this isn't necessarily going to cause the stated Error 33 if the faulty connection is in the supply side of the controller. I might be wrong though.
Does anyone have experience with Ananda controllers? I'm also interested in what looks like a UART pin out loom and whether I can adjust parameters). There is not much online under Ananda controllers - well about hacking repairing them any way. The controller model is 3618DLC. Keen to know if another common brand of bike uses these.
I've asked Smart Motion NZ for parts pricing and supply info, but half expecting not to hear back. I have found the Smartmotion AU parts page, but it doesn't list the male battery connection pins (housed in the controller/bikeside receiver).
Hi,
Hello,
I'm not sure if this will help you, but mine was fixed.
I have Ananda controller MC5-BO, 36V. Sure, my controller is different than yours, but anyway we had the same error.
I got error 33 on my display. The issue started after heavy rain when I was biking without the possibility to find any cover. After reading the manual I checked all contacts as you did. Everything was ok. Because the issue started after rain and there was some moisture inside of my display, I tried to fix the issue by warming the display with a hairdryer. It didn't help. There was still moisture in the display.
After I opened the display, a few drops of water could be seen in it. I dried the display with a hairdryer, checked if the issue was fixed, and it was ok. No error anymore. I closed the display and protected it with clingfilm. No issues or errors occurred after the drying.
Hope you get your device fixed.
