Spoke tension adjustment...
Wetstuff
As a geezer with too much curiosity and time, I watched a video on Spoke Tension. Hmmmmm... I put this rear trike wheel in my lap and did a round-and-round ..top/bottom One spoke was -4 under the general 3-32 kg range and one was 4> over. They're all balanced now! My next project is to see if I can get a bit of wobble out of my RR wheel. There's a fellow in FL who did a nice YouTube demonstration on how to do it easily.. I likely will make it harder, but press on...
Jim/Salsbury MD
I bought the same spoke tension gauge.
It's got a adjustment screw on it so you can calibrate it.
I had countless hours of fun warping and unwarping my wheels. 😁
Left and right wobbles aren't too bad to straighten out, but I've always had problems trying to get rid of a flat spot or high spot.
The worst part is when you end up making a flat spot trying to get rid of a left-right wobble.
You have to try to loosen spokes one way as much as you tighten spokes the other way to avoid making flat spots or high spots.
I've wobbled more wheels with one of those. The last few I've done I do by the wheel truing stand and gauges keeping them straight and true and when I'm done I'll check with the tension gauge to see where I am at. I am usually on the low side and have to go around tightening by 1/8 or 1/4 turn in the end. Be careful if the hub is offset or one spoked side longer than the other, one side will always be lower on tension. I figure if the gauge shows them within a certain range they are good. The thing is to get each side to sound similar. Tight is not necessarily stronger, but even tension is the strongest. And a straight and true rim will make you the happiest:)
