spokewrench
- USA
Nine years ago I bought a 14 A electric chainsaw. It still cuts fast.
A couple of years ago, a neighbor wasn't making headway with his gas saw. The teeth were very dull. I brought mine over. Because of a design flaw, it would leak until the oil tank was empty while sitting on a shelf. So I'd empty the tank before putting it away. That morning, I filled the oil tank and ran it while pointing it down at a sheet of paper until I saw oil spots. The neighbor was amazed. He hadn't known a chainsaw needed oil.
A couple of days ago, it started cutting slowly. The teeth looked clogged as if they weren't getting oil. I took it apart and cleaned but couldn't get oil to flow. Without instructions, the task to getting to the pump looks daunting, and I probably couldn't get replacement parts. So I oiled the upper groove in the bar with a squeeze bottle, and it cuts much better.
It would be great if I could press a plunger instead of fooling with the squeeze bottle. In the 1980s I had a gas saw like that. I don't remember if it also had automatic oiling.
Anyone else use a squeeze bottle to keep a chainsaw lubed?
