bought a gas generator for myLiFePO power station
Is it an inverter generator? They seem to be a lot more efficient than the regular versions.
I don't think I used the word "inverter." My generator must have an inverter because the RPM can change, but it still puts out AC at 60 Hz (I presume). Inverters may be 75 to 98% efficient. I don't know the inverter efficiency of my generator or the power station I bought.
If it's got an AC outlet then it's a generator with an inverter.
If it only has a 12V DC output (or 24, 36) then it's just a generator.
I didn't know that there was a DC only gas powered generator until now.
But I know how to make one,..
Remove blade from your gas powered lawnmower, and replace it with a Huge bicycle chain wheel.
Drill hole through deck of mower.
Install alternator through hole in deck with an 11 tooth Shimano sprocket on it.
Connect sprockets with bike chain.
I haven't done the gear math on it yet, but you might need two freewheels and two chains to spin the Alternator shaft fast enough?
Those Hondas work great for small loads. Strapped to the back of a bike, you're nuts. 😁
I was thinking of installing it on top of my top battery to move the weight forward and get it fully sprung. 😁
