REVIEW: QR-E 250W ELECTRIC BOOSTER BICYCLE MOTOR AND B60i AND B70 BATTERY
Just got the qiroll recently and have been riding more often and further than ever. It's barely even noticeable when installed near the chains.
Stock friction tape sucks and only lasts around 10km before falling off. Tried the floor grip tape which lasts maybe 50km for me. Currently trying out sandpaper belt for belt sanders which seems to be the best option so far. Also started to design a better TPU tape to 3d print.
Nice stealth setup, barely looks like an ebike. Keeping things looks like normal commuter bike.
My current bike setup. Battery still running well everyday.
Anyone have experience with installing qiroll on a Brompton? I know there's an installation on their website (https://qirollshop.com/install/) that says it's compatible, but it looks like installing in the rear triangle will interfere with the seat post from engaging the seat post stop in the folded position.
Has anyone installed this kit on a bike with a carbon frame?
I have a Giant Defy road bike, with a carbon frame, and I'm looking for a DIY kit to give me a boost on the hills.
Is the roller pressed against the tire 100% of the time? If so, I'm wondering how much of a drag it creates, when riding with the power off (or does the power have to be on all the time?)
There are pictures of carbon bikes with Qiroll installed including one somewhere in this thread. Some people have used what looks like a putty substance between the attachment plates and the carbon tubes, I assume for protection - I'd be cautious to avoid crush damage. The roller can be easily mechanically retracted from the tire with its screw knob. With power entirely off (battery disconnected) and motor on the tire there is some drag but if the battery is connected there is an "electronic clutch", as they call it. As long as there is power to the unit it spins the motor negating any drag and providing a small amount of assist if the wheel is turning beyond a couple MPH. There are only two levels of assist (other than the "electronic clutch) activated and toggled between them with buttons on the control. There are significant limitations: you have to press a button continuously for assist (besides the "electronic clutch" default), The friction layer is notorious for slipping on anything other than a smooth tire tread and on a wet tire, the stock friction layer is also prone to early failure. I have the "Mute Plus" version, it provides assist on flats and more gentle hills but not when I really want it - caveat is that I live where the hills are long and steep, up to 20+%. I have no experience with the Pro version but 3dxl reports indicate it to be much more powerful and helpful on hills. I don't see a lot of other complaints about lack of assist on hills so maybe it's just me.
I gave the Qiroll Mute Plus another test run yesterday on a 19+ mile ride that doesn't have steep grades - total 600 feet elevation gain per Google Maps. The battery wasn't fully charged at the start but all 4 indicator lights were lit, at the end of ride one was lit and another flickering. I used boost generously except when the power cable detached from the drive unit which was frequently when on rough pavement. I didn't notice slipping using sanding belt as the friction layer along with a spring hinge adjusted to maximum torsion, Continental Double Fighter tires with Tannus inserts. I'm going to silicone glue a short power extension cord on the motor (along with a short USB micro data extension) to prevent them from pulling out of the drive unit. I don't want the full length cables glued.
On my bike setup 100% of the time pressed against the tire. When power off = lots of drag (depends how tight you push the clutch roller to the tire). I run with power on all the time for commute to work.
Planning to get brompton (cheapo clone) and fit with qiroll soon. Wait until i get the budget and post my setup here.
Any update on the more powerful Qiroll prototype that you are testing 3dxl?
No updates, i don't see any releases on the powerful Qiroll on their website either. After i send feedback about the prototype unit being not able to fit on normal size "performance" bike they seems to immediately getting back into the drawing board trying to make adjustment to the clutch limit reach issues....its way to big to fit to touch the tires. It needs longer rear bike triangle frame/chain stay to fit in between it. I try to fit on common bikes ranging from mtb frame 26" wheel up to 29" ~700c none able to fit in. I was wondering how they they able to release a prototype without even test it on performance bicycles. I suspect its was build and tested on some folding bike or "cruiser" with longer rear triangle stays. Else maybe i'll used it on push scooter if it still doesn't fit on a bike, lol.
I found the stock Qiroll two button actuator difficult to use while wearing gloves, the old version with a toggle along with a mode button would have been better for me but unfortunately discontinued.
A while ago I made an actuator switch with these momentary push buttons.
It worked well but the buttons aren't robust enough for this application and one jammed and broke after minimal usel
So I substituted these momentary blade switches, hoping they hold up better. I'm experimenting a bit with locations that suit me best. Inexpensive and easy to make if you can solder fine wires.
If anyone has a better solution please post your idea(s).
Yes the old version "trigger" switch was comfortable and easy on my cycling glove too. However after a year expose to heat weather and sunlight the plastic case breaks spilling all those switch parts guts out. The button type is robust/durable but hard to press and hold constantly throughout the ride. Wish they re-introduce back soft trigger switch than button.
It's been quiet here for a while so here's a bit of an update.
I did a bit of testing of the non-Qiroll friction drive and hope to do a longer test ride on a 15-20 mile hilly route tomorrow. It is much more powerful than the Qiroll Mute, automatically retracts from the wheel when not in use and has a brake cutoff switch that requires assist level to be reset after brakes applied. It is also pretty sturdy which is good since it hangs down pretty low. I dropped the motor hard on a concrete driveway from about 3 feet height directly on the side of the motor resulting in the actuator arm being slightly bent - I was finally able to straighten it trying a vice, then hydraulic press and finally a couple pipe wrenches without any apparent major damage other than surface marring of the aluminum arm. It weighs 4 pounds so it doesn't provide the weight advantage a QIroll does and it will require that it be removed in order to remove the rear wheel. Removal and replacement is very easy and quick though with only a 13mm wrench so that isn't as much of a negative as it might otherwise seem. I'm curous how well it will perform on tomorow's ride if all goes as planned.
I also tried a different self closing hinge on my Qiroll. It seems to work well and with this hinge it is simple to mechanically disengage the motor from the wheel simply by putting any sort of spacer in the hinge to hold it open. The other spring hinge that I've used required the hinge to be compressed to disengage which is more difficult to accomplish.
Lastly I'm going to modify my current fabricated USB micro control switch with latching push buttons (so a button doesn't need to be continuously depressed to actuate assist) along with a brake cutout switch that will temporarily cut assist when brake applied even if the latching push button is still engaged. Hopefully that will work better than the stock control.
The non-Qiroll friction drive in the image above burned out after 7-8 miles of riding on a hilly route. Up until that point I thought it worked pretty well with significant assist although I was putting in a good amount of effort pedaling. It died suddenly on a 12% incline (per Garmin) in level 4 of 5, again with me inputting a lot of pedaling effort, motor was quite hot. YMMV but it didn't work out for me. Of note my Qiroll Mute Plus on the same bike had survived without an issue on the same route although it provided significantly less assist.
Here's where it died, appropriately along side a cemetery.
To answer my own question about Brompton compatibility.
It does fit in the rear but involves removal (or trimming) of the mud guards. Fold is affected because the seat post doesn't go all the way down. There is also this option for front mounting which I might explore at some point:
Would the Qiroll quick release help with your folding/seat post interference issue? It's not expensive, $24 USD.
At one point I installed my Qiroll on the front fork of a 26" bike that had an easy install unlike your Brompton. It seemed to work as well as it does on the rear wheel (caveat, I only did a couple short test rides).
The quick release would help in the sense that the motor can be removed without tools, but that's not something I can see myself bothering to do every time I fold so I think I will just have to live with the slightly bigger folded size.
By the way, where did you get that spring hinge from? I can't seem to find anything similar at my local hardware store
The spring hinge is 3" stainless steel that I got off Amazon. I needed cobalt drill bits to make the Qiroll attachment holes and one for a bolt to the kickstand platform, if you don't have cobalt bits it might be better to source a hinge that isn't stainless. I have used a similar 4" hinge on a different bike where I mounted the Quiroll on seat stays but 4" is to long for this bike and location (would hit chainring or left crank arm). Couldn't use 3.5" self closing hinges because the knuckle/barrel portion length is the same as on a 4" hinge.
Yeah, I abandoned the idea to drill my hinge to mount directly to the motor, and then also had to return some brackets I thought might serve as an adapter but didn't quite fit. Considered a few other options but ended up designing an adapter to have 3-D printed, which should arrive any day now. Hopefully soon after I'll have this thing on my tandem.
Bummer that other (non Qiroll) friction drive motor burned out so quickly! Short lifespan + weight penalty doesn't sound like an appealing combination.
Interested in your latching switch project. Certainly a neater solution than the rubber band I've used to hold the switch closed!
Interesting, post up when you get your custom printed adapter - I hope it works out like you want.
I had my reasons for the non Qiroll purchase but my experience with it is a reminder for me to not have a credit card close by while browsing on the computer with my morning coffee - lesson learned (sort of).
