Nvreloader
Western Nevada
- USA
Well guys, the new fork got here AND,
I am not comfortable about this front axle length fitting in the new suspension fork,
I have the following measurements for the fork and axle on the front hub.
Fork measurements: (Where the axle locks into the fork)
Inside distance/space = 3.390"/86.10mm
Outside distance/space= 4.590"/116.58mm
Fork thickness for axle bearing surface = .310"/per side =.620" total bearing width
Axle slot width = .400"/10.16mm
Formula Hub, 32 spoke hole, 14ga spokes, (Quick release type axle/skewer)
AXLE measurements:
Length = 4.090"/103.88mm
Axle Diameter = .3450"/8.76mm
10- 3/16" ball bearings per side
Axle only has .065"/1.65mm on each axle end for the bearing surface in the new fork slot,
THIS AMOUNT DOES NOT SEEM SAFE TO ME?
Should I get a longer axle length, some where around 4.25/4.50",
so I can have a longer axle bearing length support?
The 1/16" axle length does not seem safe to me, with a QR axle....
There is about 1/4" = .250" of axle bearing length on the OEM fork.
Tia,
Your thoughts and suggestions
AXLE measurements:
Tia,
