Bosch Connect Module (GPS)
I've testet the alarm and it works as expected. If I move the bike a couple of meters a pretty annoying alarm starts and I get a push notification on my phone.
I can use the kiosk 300 display or phone to lock and unlock the bike.
Only thing I haven't found, is the page in the flow app where I can see the bike location. Maybe it does not work as I had expected.
EDIT: I found out about the location tracking. So it seems like the bike only transmits locations when it is parked or when the alarm is triggered - which makes sense. I can see where I parked my car in the flow app under the “Protected” headline. It writes the street name and city, and if I click it I get it on a map. 👍 Later I’ll try to see how it looks when the alarm is triggered.
Overall I’m pretty happy about it. It works as expected - given that it will scare thiefs away. Only time will tell if it was a waste of money.
Now I just need to find a nice bright “GPS Tracked” sticker that I can put on the bike. Would be cool if Bosch had included a sticker in the kit. There is a “Bosch protected” sticker but I don’t really like it and it broke when I tried to ut it on my bike.
What is the model number of this alarm?
It’s called the Bosch e-bike alarm and connect module. Think the model number is BCM3100 although there are two kits available, one to fit the performance motor and the other for the CX line. The only difference in the two kits is the plastic module holder. You can purchase the module and holder separately but it’s advisable to get the full kit as it includes the plug in cable. I’ve only found one supplier in Canada where it’s readily available.
Completed the three new motor cover install today, to anccept the Connect Module, and will say it was a little more complicated than I had anticipated. Took me a while to figure out what needed to be done to remove the two right side covers but finally figured it out. As usual You Tube was a great help. Pretty straight forward but took little time once I had the steps figured out. The sketchy part for me was removing the belt ring to get enough room to remove the top right cover. But that was necessary to install the new cover. Luckily I own a torque wrench which is necessary to retorque all the bolts per the specs. In hindsight, probably would have taken it to my LBS but learned a lot including how to remove and reinstall the rear wheel which I expect will come in handy the day I get a flat. So far everything works as it should.
Here’s a few pics I took along the way.
Looks better than my solution :) I might replace my engine cover later.
Thanks for this. I’m interested in the Tern NBD S5i but cannot get answers whether this model has the internal alarm
From the pictures on Tern's website, looks like this has the Intuvia display, which means it is on the last gen System 2 and not the newer Smart System HW.
Bosch Connect Module is only for Smart System bikes.
FYI - the Intuvia can be removed from the bike when you park, rendering the bike unable to turn on. Not the same, but also not nothing.
The HSD runs on the Smart System so the module being discussed here could be added to the P10 and already comes with the S00.
Thank you !
I have a Gazelle Avignon C380 Smart System. I opted for a simpler modification to install the Bosch connect module, under the handlebars. Here the module is in a near-vertical position, but I have tested it extensively and the alarm etc works perfectly. As the connection is simply in series with the display cable, it can be fitted using the short cable supplied with the Module. You will need to drill out the hole in the metal bracket to accommodate the steering head clamp bolt, and then shape the bracket to fit under the bars. It is necessary to cut off the plastic nib on the nose of the module. Photos below. Let me know if you need more info?
ps: the bike comes with Gazelle's version of GPS module, but after testing I realised it is not as fully-featured as the Bosch, hence I purchased the module online and fitted it myself. Thanks to this forum, I did not bother with trying to fit it in the conventional position under the motor covers!
LBP, which YouTube movies did you use? I’m facing the same operation as you did. 😅
Curious if some members could shed light on the Bosch Connect module. It appears to be a $100 device that can be stuffed in the motor housing to provide GPS tracking and navigation.
Does navigation work well via the Kiox or Nyon displays?
How does the alarm function work?
Does the device require its own ongoing cell service subscription?
Does a user install really void the motor warranty?
Are there any other Bosch modules to consider to know How to Setup a GPS Sensor on the Arduino? - Technetron Electronics?
The Bosch ConnectModule is a security and tracking device designed for Bosch eBikes with the Smart System. It enables GPS tracking and an alarm function that triggers a sound if the bike is tampered with, sending real-time location updates via the eBike Flow app. While it doesn’t enhance navigation, the Nyon display has built-in GPS, whereas the Kiox requires a smartphone connection. The module does need a Flow+ subscription for tracking and alerts. Bosch recommends professional installation, as self-installation may void the motor warranty. Other Bosch modules like eBike Lock, ABS, and SmartphoneHub offer additional features.
I had the connect module installed on my Cannondale Mavoro Neo 1. It’s a great added layer of protection.
There We’re no issues on installing it in the housing which is the Bosch performance speed motor.
