fooferdoggie
dont tell anyone of my side income.Must drastically increase the efficiency of circumcisions and the resulting production of all that foreskin jerky
Instead I just received this one:Here's a tool to NOT buy:
Shock Pump
High-pressure, low-volume pump capable of reaching 300 PSI/20 BAR for shocks with Schrader valve connections. 1.5” industrial gauge is easy to read. Ergonomic T-Handle and 6” swivel hose with pivot mount make it easy to pump in any angle. CNC machined alloy head and barrel provide strength...probiketool.com
Pro Bike Tool Shock Pump...
Every time! My buddy loved to wrench on cars. He thought me this. He is left-handed, so I think it was natural for him to start that way.My SOP (Standard Operating Procedure) for many threaded things is to first turn them the loosening way until the lead thread "pops" off the other side's lead thread, at which point any tightening turning engages right away.
I got this RockShox unit...Here's a tool to NOT buy:
Shock Pump
First, it's hard to pump once you get beyond about 120 psi.
Second, the release valve seems to let out air, and not just the air in the hose as claimed. That's because the screw action is so slow.
Third, in order to use it you're holding the end that has the air release valve and gauge. So you either accidentally release some air while pumping unless you hold it just so.
Fourth, and the fatal flaw, since you're holding the gauge, you're putting pressure on it and it's just plastic, so after a few uses you'll probably do like I just did and break the gauge off.
"Other than that, Mrs Lincoln, how did you like the play?"
I have the same pump and it hasn’t let me down.I got this RockShox unit...
Below, we review nine shock pumps to see what the options are. Keep in mind that many of these pumps come out of the same factory, and so many share damning similarities – as apparent by the key measurements.
If you were to slip a little O ring over that lever, it might provide enough friction to mitigate that problem. Or make it go away. Or fix it. Or whatever.a ratchet driver. it gives you leverage and three pits held by magnets my only complaint it's too easy to flip the lever to change directions.
View attachment 88885View attachment 88886
	Where did you get the miniature dollhouse chair?Here's one probably most have never seen.
Under 20 of them were made in the early 1900's. Not many of them are left, but those that are still working all reside in Lancaster. This one was in Holmes County Ohio in a harness shop that was going out of business. They had two of them and both ended up in Lancaster.
Huge isn't it? It weighs almost 1000lbs. I think I know which shop one of them ended up in. I had a local carriage shop fix the top to my large canopy. They were using an industrial machine, but not one like that. Nice young Amish man fixed it for me. Those going into Amish shops mean they'll get used for another 100 years.Where did you get the miniature dollhouse chair?
I do my best to buy vintage tools to use in my workshop. The oldest one I have is a Sprunger Jointer made in 1958. I have a lathe from 1962, Radial Arm Saw from 1977, Table saw from 1987 a Rockwell full size Drill Press from 1965. Some of them needed fixed when I got them, the lathe, I'm the second owner.@JedidiahStolzfus,
A 200 year tool, what a contrast to this disposable economy of today. I see people with a drawer of remotes for stuff that has come and gone. Right now I am making a $100 bike. I purchased it for $100 and am thoroughly overhauling everything. That will push out its imbedded carbon footprint another 12 or 13 years. It is a beautiful bike that is perfectly good if maintained. Maybe it can be overhauled then again. People will toss stuff out to the landfill just to acquire the next shinny thing only to toss that out. I agree with the point of view of using quality tools and skills that will never become obsolete.
I have some of those.It is funny. Just moments after posting the above as I was installing fenders, at that moment I needed to make a tab on the rear to fit the stays behind the center kickstand. The tool for that was 18" long 1890's tin snips.
