PCeBiker
No-Hands No-Pedaling No-Credentials
- Canada
Maybe you're doing this, don't know, but I do XT60's and most other large connections by tinning the wire first, then filling the terminal on the connector with solder. While it's still hot and applying heat from the iron, you slip in the tinned wire, hold it there for a few seconds then remove the heat.
Yup.
I figured that out the hard way after melting the insulation off a bunch or wire by not using a hot enough soldering iron and not tinning the connections first.
What sucks for me is the lack of lead in the new solder.
I suck at soldering with the new lead free solder.
60/40 tin/lead electronics solder with resin core (not acid) is getting hard to find.
We used to hold the lead core solder in our mouths in school to leave two hands free to line up the parts to be soldered.
I managed to get this battery connector cable soldered up after some practice,..
