Bbshd is heavier than the other BBS*How do I tell what the amp rating is on my BBSHD? Thanks.
And is the 30 amp SHD heavier then it's weaker brothers or are you saying it's just heavier than the Photon?
If you have the cable to hook it to a windows computer and access the program it is the second line item on the Basic page.How do I tell what the amp rating is on my BBSHD? Thanks.
I am considering the photon as well although the last thing I need is another ebike.This making the Photon a good candidate for my needs. My concern is reliability in general, not over working it and whether or not the app interface is some buggy p o s
Funny you should mention that!Does it come with a backpack battery is my interest.... Kinda like an umbilical cord?
Where does the cable plug into?If you have the cable to hook it to a windows computer and access the program it is the second line item on the Basic page.
It uses the display connector. You unplug the display and use the USB adapter to your PC or Phone.Where does the cable plug into?
penoff.me
What @Gionnirocket said. Nowadays, BBSHDs that are rated for 52v are locked down to 28a as well. Thats a fairly new thing. Supposedly they are also a bit gutless. I have one from California Ebike that I decided not to use once I heard that last part from people using them and wondering wtf was up. Its not just a loss of 2a of current.How do I tell what the amp rating is on my BBSHD? Thanks.
The way I look at it, the BBSxx crankarms are crap and have to be replaced. The Chainring is the same. So with today's insane prices, you are looking at perhaps (on a good day) $75 for the chainring and another $75 for the replacement crankarms. That assumes you do not use Lekkie parts. If you do the cost is quite a bit higher. So add $150 at minimum to your BBSHD buy-in. At Cali Ebike those prices work out to$850 USD price tag is pretty hard to swallow though especially for the power.
No but thats what I had to do with my Cyc X1 motor.Does it come with a backpack battery is my interest.... Kinda like an umbilical cord?
Been there and done that. XT90 and a janitor's keyring thing to let the cable ride close to your body yet extend and retract automatically as you ride and maybe stand up on the pedals and sit back down again. Use a hardshell pack in case you go flying, the battery doesn't take any kind of an impact. Wrote the whole thing up here.The issue would be the battery connection (reliable yet quick disconnect). A XT60 would likely work. A rosenberger(used on Brose/Specialized) would be better but mucho $$
He told me this is more in league with a BBS02 rather than a BBSHD - certainly the motor's torque numbers bear that out.
Ok... But if we're really in the neighborhood of the BBS02B... then the weight should be compared to 9.5lbsBig thing for me is the 14 lb BBSHD versus I think 7 lbs for the Photon. Thats enough to matter.
Yeah, I added up the cost for my latest BBSHD buildThe way I look at it, the BBSxx crankarms are crap and have to be replaced. The Chainring is the same. So with today's insane prices, you are looking at perhaps (on a good day) $75 for the chainring and another $75 for the replacement crankarms. That assumes you do not use Lekkie parts. If you do the cost is quite a bit higher. So add $150 at minimum to your BBSHD buy-in. At Cali Ebike those prices work out to
A Bafang kit with no crankarms and no chainring, including the main bus cable, speed sensor, a display and a throttle. That comes out to $760 at Cali Ebike. Add $150 for the bargain versions of chainring and crankarms and you are now over and above the cost of a BBSHD kit at $910. Go Lekkie and you are WAY over. The thing about Cyc kits is they give you everything whereas with Bafang stuff you get nickel and dimed.
I do better than the above pricing by buying bare motors from Luna for $100 less, but I am still above the cost of a Photon when I add in the fancy motor cover that lets me put on a 40T Lekkie ring. My Shimano crankarms left over on a shelf in my workshop on my last build at least kept me away from the $150 Buzz Bars.
What other mid-drive has the power, parts stream, support, and proven performance? And with no sarcasm intended our Grin motors and parts surely aren't on a budget?$850 USD price tag is pretty hard to swallow though especially for the power.
No arguments on the benefits of the BBSHD, so easy to make a clean 36mph capable bike....I love mine. If I could have only 1 DIY bike, it would be equipped with a BBSHD.What other mid-drive has the power, parts stream, support, and proven performance? And with no sarcasm intended our Grin motors and parts surely aren't on a budget?![]()
Yeah but the waters are a bit muddy there. The Photon is not a straight-across comparison with a BBS02 as its more powerful - when unlocked. Even if it wasn't thats still a 2.5 lb weight loss.Ok... But if we're really in the neighborhood of the BBS02B... then the weight should be compared to 9.5lbs
Well c'mon good man... make up your damn mind!!!Yeah but the waters are a bit muddy there. The Photon is not a straight-across comparison with a BBS02 as its more powerful - when unlocked. Even if it wasn't thats still a 2.5 lb weight loss.
Regardless its just a curiosity to me. Want to see if they change the cable exit in a future generation as that doesn't seem like such a great thing as-is. Livable for something like a Bullitt but bad on a conventional frame.
A few years ago I found a TTL female to Higo adapter to use a Grin TTL-USB cable. Being 3 meters long is very convenient for me. I hate juggling my notebook around on a 12-18" cable. Sadly they were expensive and now unobtanium. If anyone finds a source for budget priced small order Higo connectors, please share?It uses the display connector. You unplug the display and use the USB adapter to your PC or Phone.
The phone does require an additional USB to Type C adapter
Speeed - Bafang BBS01/02 BBSHD - Apps on Google Play
Easy and clear programming tool for BAFANG BBS01 BBS02 BBSHD ebike motorsplay.google.com
E-Bike Conversion – Software
It’s been a while since I wrote the posts about my electric bicycle conversion project. The bicycle runs fine so far and I finally finished rewriting the software that configures its controll…penoff.me
