fooferdoggie
I like the comfort of those 2.35" tires but they really slow the bike down. My bulls with the older bosch motor and 1.5" tires would accelerate far better and I tended to go about 3mph faster. I went tubeless on out tandem and it really improved the ride.
The problem with tubeless is the cost. Two new tires (75.00 each) for Schwalbe G-One Speed 2" tires. Then you need rim tape I sued the best rated dt-swiss its 27.00 a roll and will do three rims with two layers. Then valve stems I used muc-off they are 30.00 for 2. Then you need a sealant. I will use the new flat-out for small tires. Thats what I used in my tandem wheels and they have not lost air in 3 weeks. https://shop.flatouttire.com/collec...s/products/1-pack-quickstrike-small-tire-16oz
Then you need either a compressor or co2 to get the bead set.
Also a good idea is a plug kit in case the flat out does not work I bought the best rated one they have a lot but I got the lower end version they have a cool one that will pump your tire up and then seal it. http://www.dynaplug.com/bike.html
Hope to have it all Tuesday. No one had the tires locally or the tape in the right width.
