tomjasz
- USA
- City
- Minnesnowta
No!Thanks. Understood, but, would a non Bosch Lectric type battery be counting cycles, and count that as a cycle? Will such a battery shut itself down after counting the max cycles?
You guys are free to do as you like. I will continue using my OEM chargers, using the directions supplied with them, as will 99.99% of other people buying ebikes. When you convince the OEM's to recalibrate the shut off points on these OEM chargers based on a belief of your/Grin's "scientific evidence", I'll start using that recalibrated charger, letting it run until it shuts off/indicates a full charge. You do your thing, I'll do mine.SO! now science is mumbo jumbo? Come on Al. It's not just Grin. See the data Ravi has posted from a SCIENTIST! The batteries I religulously used my two Satiators on were the longest lasting. It's not something Justin pulled out of his arse. Don't let your criticism of the looks of the CA2 and CA3 cloud your thinking.
Sure Al I get that. Do your own thing, but denying good science seems silly. I care less what 99% do. These days disinformation abounds. LED lights make skin orange, climate change is a hoax, toilets have to be flushed ten times, wind power kills all the birds, and... oh never mind. Once you make up your mind facts be damned...You guys are free to do as you like. I will continue using my OEM chargers, using the directions supplied with them, as will 99.99% of other people buying ebikes. When you convince the OEM's to recalibrate the shut off points on these OEM chargers based on a belief of your/Grin's "scientific evidence", I'll start using that recalibrated charger, letting it run until it shuts off/indicates a full charge. You do your thing, I'll do mine.
My bigger point is this. If I am able to get the 600 plus charge cycles that they commonly advertise, and I'm averaging 30 plus miles on each of those cycles, that's 18,000 miles. Why in the world would I want to jump though any hoops to extend the life of this battery any further?Sure Al I get that. Do your own thing, but denying good science seems silly. I care less what 99% do. These days disinformation abounds. LED lights make skin orange, climate change is a hoax, toilets have to be flushed ten times, wind power kills all the birds, and... oh never mind. Once you make up your mind facts be damned...
I think Ravi lays it out pretty clearly,@tomjasz
I am curious as to your opinion (one I do respect on this topic) regarding avoiding storing or holding batteries at a charge level above 80% being the primary concern. As I said earlier, my research has lead me in the direction of keeping my batteries below 80% but charging them fully just before going on longer rides such that they are not at above 80% charge for more than an hour or so. Any time they sit idle they are held between 40 and 80 percent. My own anecdotal experience doing this for the past 4 years is no perceptible loss of battery capacity on any of my bikes.
To quote Grin on this, "drastic improvements in calendar and cycle life when they are not held at the nominal full charge voltage of 4.2 V/cell but are charged to a lower voltage instead." I take the word held to mean stored. Grin does not specify just what the harmful holding period is.
It is also my understanding that in order to keep the cells balanced, the charger needs to take the batteries to a full 100% charge to complete the balancing process. This implies that it may reduce battery life to never bring them past 80% charge.
Do I have it wrong that storage or holding the batteries at above 80% charge is the real issue but there is little impact in charging higher so long as the battery is left in that state for any length of time?
				 electricbikereview.com
				@Ravi Kempaiah has been a valuable contributor and a source of solid, trustworthy and reliable information on this forum for quite some time. I remember this post well. Thanks for reminding me about it.I think Ravi lays it out pretty clearly,
E-Bike Battery Guide
This thread is dedicated for helping new E-bike owners to understand and maintain their batteries in the best possible way. There is a lot of confusion for any new E-bike owner as to how one should treat their batteries: Shop owners may say one thing, online resources may another thing, someone...electricbikereview.com
He works with renowned experts.
				Both of my triangle packs from early 2016, they only started selling them in late fall of 2015, aged out on me. Total saggers! But one EM3ev pack from 2014 that was “Satiated“ is still pushing a buddies bike with no issues.Luna in 2015.
I’ve discovered with my EM3ev BT BMS batteries that’s not the case. I’ve never done an 100% charge in 4 months and the BT app on my iPhone shows all balanced cells. I believe Mikey V’s battery also has a BMS that does the job. Does Bosch give you the ability to choose percentage of charge? My buddy here just charges and rides and got 14,000 miles on his original Trek/Bosch.(in fact to achieve balancing it has to be done from time to time).
Bosch does not have any options for charging to less than 100% (unless that really is not 100%I’ve discovered with my EM3ev BT BMS batteries that’s not the case. I’ve never done an 100% charge in 4 months and the BT app on my iPhone shows all balanced cells. I believe Mikey V’s battery also has a BMS that does the job. Does Bosch give you the ability to choose percentage of charge? My buddy here just charges and rides and got 14,000 miles on his original Trek/Bosch.
Well given the mileage my friend is getting and he NEVER does anything other than plug it in and unplug when it shows complete, the system must be doing something? No?Bosch does not have any options for charging to less than 100% (unless that really is not 100%I am left using a timer between the AC plug and the wall outlet. The timer four options, on or timed for 1,2 or 3 hours. From experience each hour is about 30%. If I get home from a ride with 20%, I give it a two hour charge which brings it up to 80% (if it is more than 20% I give it an hour of charge). Then an hour or two before riding, I top it off to 100% and go. That's my story and I'm sticking to it.
