DiggyGun
- United Kingdom
- City
- Buckinghamshire
Another day out on a disused railway line, this time in Northamptonshire. It is now called the Brampton Valley Way, which closed in 1965. It was used for a small Iron Ore Quarry and used to run from Northampton to Market Harborough. At one end now, is a preserved railway line called the Northampton and Lamport line.
Quite interesting to see some if the old railway infrastructure and paraphernalia in place.
Although basically a straight line the trail trail does have some interesting features, including two tunnels that you can go through which was good fun. We use Moon USB lights, which have a high lumen rating, mine on full power is 4000 lumens, so the tunnels were nicely lit up.
The weather was extremely kind to us today with virtually no wind and the temperature around 12oC. However, with the sun out, we actually had to remove the gloves and some layers as we got too warm.
All was going well, until I got a puncture at about 20 miles, unfortunately, that was about ten miles from our van. Luckily it hadn’t gone completely down, but was soft. So I checked it over and found nothing sticking out. Took the risk of re-inflating the tyre using my CO2 kit, pumped up OK and so we rode the ten miles or so back to the van with no further issues.
So far it has stayed up. Looks like the WeldTite sealant is doing its job, but will check it again in the morning to see if all OK.
Here are some photos from today.
Today‘s stats.
Today‘s stats.
